Hey guys, I'm contemplating selling my evo, some say there car is "capable" of making 500kw, but it's on 240kw, all u need to do is spend another 30k to get there but it's "capable" , this is one of those evos that have made the power it's capable of, and a lot of money, and time has gone into this car, well over 80k not exaggerating... If I sit and count what the parts cost plus labour it would be over 100k... And it's got the best of the best gear in it.. Rarely get driven, the only thing left stock in this car is the 6 speed box and diffs, it has 9 months nsw rego. Less than 1500km ago, Engine has been refreshed with new bearings, gaskets, etc, head has been refreshed as well. New complete precision turbo set up, new brake pads, new clutch, new tyres... Spent over 25k in the last 3 months.. So here's the mod list
price is $46000
PICS ARE HERE
http://s1037.photobu...s?sort=3&page=1
Car was built by ChasersMotorworks in Melbourne if you want to know a bit more about the history feel free to call them.
Engine Modifications:
- HKS 2.3L forged stroker kit. - engine opened up and refreshed with new bearings, gaskets, etc 1500km ago
- Precision 6466 turbo with custom powertune manifold- 1500km ago
Turbo smart wastegate 1500km ago
M&w ignition 1500km ago
5bar map sensor
- HKS type R intercooler kit
- HKS type R oil cooler kit
- Id 2000 injectors
Big fuel setup and surge tank, braided fuel lines
- Tomei adj. cam gears
- Tomei Procam 270/270
- Hypertune Intake manifold
- Hypertune throttle body
- Tomei fuel rail, braided fuel lines
- Sard fuel regulator
- PWR 57mm radiator
- Ferrea oversize valves, guides, springs,
- Solid engine mounts
- Heavily ported, machined, polished head- 1500km ago
- Motec M800 ECU
- Tomei Sump baffle
- Solid lifters
Suspension/Handling Modifications:
- Ohlins Flag L coilover suspension w/external res
- Alcon monobloc 6piston 365mm front brakes
- Alcon monobloc 4piston rear brakes
- Rose jointed
- All aftermarket suspension arms
- Adjustable sway, camber, toe, castor, bump, rebound etc
- Summit tower brace
- Summit boot bracing
- In cabin floor bracing
- Under car bracing
Drivetrain modification:
- Cusco front and rear Differential LSD's
- ORC twin plate carbon clutch
- Rays RE30 10.5x18 wheels
Yokohama AO50 semi slick. 265/35/18 driven only 3 times with these new tyres
Eboost 2
Oil pressure and oil temp gauges
Evo 9 front and rear bars
Varis side skirt
Varis rear wheel arch to tuck in the 10.5 wheels. Otherwise they will be sticking out like dogs balls.. The car had a time attack body kit on it which I took off but had to leave this only for the wheels.
Body is in good condition. 1 dent on it on the door. Some scratches on the bottom lip.
Interior is standard trim
This car is nuts to drive, it comes on like a motorbike, and handles like it's on rails, and with the Alcon brakes, it stops as hard as it pulls! Well not really but I haven't tried yet.. lol..
It's tuned on e85 and made 515kw @ 40psi, can make more power with another fuel pump, but I think 515kw is more than enough on the street.. It was tuned at maatouks racing.
Car is located in burwood, nsw please call 0410158440
Price is $46,000 a bargain considering the amount of work, and money poured into this car.
PICS ARE HERE
Edited by rami13b, Today, 10:38 PM.
post-86797-0-43163200-1386245479_thumb.jpgpost-86797-0-58918000-1386245490_thumb.jpgpost-86797-0-44387800-1386245501_thumb.jpgpost-86797-0-48020300-1386245520_thumb.jpg
No gt-r madness, you read wrong, my point is that there are people who advertise there car as "capable" of making 500kw plus.. This makes what it is capable of making, 100k has been spent on this car,
But if you think a turbo kit and stroker kit will get you 500kw think again, you will need another 30k.. That's what my point was..
Both links come back to this page.
Pics in duplicate thread here
http://www.skylinesaustralia.com/forums/topic/435995-2004-evo-8mr-with-515kw-at-the-wheels-100k-spent/
Edited by timmy_89
I didn't read it wrong... it's currently 240kw and the car had 100k worth of parts and labour.. and the standard Evo's have like early 200kw... I just find it hard to believe that's all...
Edited by GT-R Madness
  • Like 1
Yes you did read it wrong, I wrote...
" some say there car is "capable" of making 500kw, but it's on 240kw, all u need to do is spend another 30k to get there but it's "capable" , this is one of those evos that have made the power it's capable of"
Some say, as in, some people selling there evos claim that there 240kw is just moments away from 500kw, and in reality it needs another mortgage to achieve this power...
Then I wrote, THIS IS ONE OF THE EVOS THAT HAS MADE THE POWER ITS CAPABLE OF
Did you still not read it right?
^ and there's the proof , If this is still up in a few months and house hunting is finally done i will contact you :)
Edit : here is his photo's link for those not working
http://s1037.photobucket.com/user/rami_13bz/library/Mobile%20Uploads?sort=3&page=1
I understand what you mean, but this was a very unclear way of saying it.
What makes it so difficult for people to understand, is you meant to write "their car", but what you actually wrote was "there car".
"There car" does not fit in the sentence, so people start wondering does he mean "their car", "the car" or "there car". If you do not use the right word it makes it difficult to decipher what you mean.
  • Like 2
  • 1 month later...
  • 3 months later...
Can I suggest rewrite the ad. I also initially read it wrong which made me laugh while reading. How many other people have read it incorrectly and moved on from your advert.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
