RB25DET
Changed out my series 2 motor with a series 1 motor due to a failing bearing. Motor is still physically okay, and running gear that has been removed is working
I have the following parts available. Pickup from Dandenong VIC or I can post at buyers expense.
Starter motor - $70
Alternator - $80
Power Steering pump - $80
Throttle Body - $80
JJR Dump Pipe to suit standard turbo (6 bolt Nissan rear) - $100
post-59604-0-81054000-1386481502_thumb.jpg post-59604-0-43354000-1386481535_thumb.jpg
Standard log manifold - $150
Standard RB25 blow offf valve $80
Timing Belt Covers Top & Bottom (painted blue) - $100
Fuel Rail - $50
Xtreme Heavy Duty Cushion Button Clutch (80%ish meat) & Pressure plate - $400
post-59604-0-66551600-1386481775_thumb.jpg post-59604-0-94193000-1386481804_thumb.jpg post-59604-0-57406800-1386481832_thumb.jpg
Coilpack bracket (S1) - $25
Coilpack harness (S1) - $40
Ignition Module (S1) - $80
Injector harness (S1) - $40
Crank angle sensor (S1) - $150
Oil Filter Housing [between block and filter] (S1) - $70
Set of 4 White Yokohama Advan TC2 rims. 18x8.5 +25 front / 18x9.5 +29 rear. Stud pattern 114.3 x 5. light weight 8 -9kg.
The front rims have Advan AD08 tyres 245/35/18 on them, the inside shows signs of camber wear so those tyres would need replacing very soon, however they still appear very grippy. The rear rims have Nitto NT05 tyres 275/35/18 on them which are completely worn and need replacing.
The front right has a small crack in the rim (on the middle part where the tyre is seated) which has just temporarily been repaired but will need a bit of welding. I got quoted approx $110 to have it fixed.
The front left rim has some light gutter rash on the outer edge of it, but it should be fairly easy to clean up.
Other then that the paint and rims themselves are in good condition
$1800
post-59604-0-41477300-1386482459_thumb.jpg post-59604-0-77908300-1386482489_thumb.jpg post-59604-0-13562000-1386482516_thumb.jpg
SMS me on 0458762075
Brent
Have you still got the whole head ?
Sent from my iPhone using SAU Community
Hey mate, I just sent you a PM. I have it still. I sent my phone number in PM too.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
