Hi guys, bought this car last month after owning a 99 Subaru Liberty for 2 years. Going from a slow boat that gets thrashed at the lights by camry's to this has been a huge jump.
Only mod I've done since buying it is install a manual boost tee as it was running wastegate pressure, although I am slowly doing little maintenance jobs that needed doing.
- Cleaned out aircon, was noisy and had half a field worth of spinifex and leaves in it, filters were blaaaack with tokyo juices.
- Wet Vac'd the entire car, much human slime came out. Car had a horrible case of the skyline smell.
Specs
Tires/Rims
Rota P45s - 18 x 9.5 +12
Nexen 7000, 235
Engine
Apexi Pod Filter
Manual Boost Tee at 8psi
Apexi N1 Turbo Back
Suspension
Crappy Coilovers
I have many, many plans for this car and have been getting ideas from other guys on these forums..
Cheers!
https://www.sau.com.au/forums/topic/436103-r34-gt-t-camry-killer/
I will chuck up some more pictures when I give it a good detail later this week. Ordered a DAS6-Pro and will hopefully get rid of all the scratches and swirls.
In the next few months
- Blitz Returnflow Front Mount
- Greddy Profec EBC
- Nistune
- Replacement Gauges for factory. Thinking of getting the 60mm Shadow BF series, any recommendations?
- Paint interior
- Retrim Steering wheel/Gearboot/Handbrake boot
- Floor matts
- Install hektic stereo from previous car.
Edited by owen1r
  • 2 months later...
I finally have updates after growing slack.
Firstly, more photos.
New Blitz Return Flow Intercooler, took forever to fit.
101b0eba-5641-467b-9831-b93cd48daade_zps
New Greddy Profec, excuse potato.
Car was initially running 6psi when I got it, now it's running 10psi. What a difference it made! So much more fun to drive.
Few other things were done -
- Walbro GSS342, perfect swap for OEM fitment using the oem fuel sock. Exact same dimensions as the stock pump, super easy.
- Splitfire coilpacks and yellow jacket coilpack loom
Should be able to get a nistune soon after I iron out some bugs, then onto some new wheels/coilovers and swaybars ect.
- Blitz Returnflow Front Mount :yes:
- Greddy Profec EBC :yes:
- Nistune :yes:
- Replacement Gauges for factory. Thinking of getting the 60mm Shadow BF series, any recommendations? :no:
- Paint interior :no:
- Retrim Steering wheel/Gearboot/Handbrake boot :no:
- Floor matts :yes:
- Install hektic stereo from previous car. :whistling:
Lol...
I run 52mm Racetech and they sit perfectly in the factory position... While you do them fit a Greddy block to your oil filter and if you can afford to try get a oil cooler kit sorted at the same time! It will help you later on once you start beating those camrys and even one day step up to the magnas! :woot:
If you need any advice just PM me as i should be able to help with some stuff! I been at it for about 6 years with mine lol
Lol...
Glad you approve of the floor mats haha.
Reckon you could fit 60mm? I like the larger dials.
Yea I'll do it eventually after I get a tune and decide if I want to stick in a AFR meter alongside oil/water temp.
Yep 60mm do go in with slight mods and look good!
I just wanted an easy install and they are easy enough to read, they beep and flash warnings if you go outside the set parameter so i dont really need to keep an eye on them in most cases. I setup Water temp, oil temp and oil pressure as they were the vitals i wanted to see... The Haltech takes care of the rest ;)
Nice car mate.
I have a R34 as well and frequently troll the internet like Mat (34GeeTeeTee) so I know everything as well :P haha
But seriously, if you have any questions feel free to ask, I've learnt a few things a long the way as well. And on the topic of gauges I just bought some 60mm Defi's that I plan to fit (when I get off my ass) so you will be able to see what they are like in my thread if you were interested :)
I pretty much agree with Mat's yes/no answers as well.
I would definitely be looking at swaybars when you can too as they made a huge difference to my car.
Plan is after a nistune I'm doing BC BR coilovers and front and rear swaybars, then look at doing a turbo upgrade. Thinking GT3076r as I want to just hit 300kw with the most response possible.
Just fixed my car finally, wouldn't start when hot and would misfire up top. Replaced the CAS and it's all fixed! Wooooh.
I would love Defi's if they weren't so expensive!
Yep I have BC BR's and Whiteline 24mm adjustable swaybars. Great mods.
I'd suggest (as will Mat) looking at Forced Performance turbos. Mat has their 3076 and I'll be looking at either that or their 3073.
I picked my Defi's up at a good price second hand, wouldn't by them at RRP sooo expensive lol.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
