  • 2 months later...
Now on the quest for new wheels, as my current wheels have about a cm of poke at the front and require about 3 deg of camber at the rears.
Looking for F - 18x8.5 + 25 and R - 9.5 + 30, I believe these will be flush and fit 245/275 tires with minimal camber.
Any input from anyone? Offsets seem ok?
  • 2 months later...
  • 1 month later...
Cheers guys.
18 x 9.0 +35 (with a 10mm spacer to clear brakes) and 9.5 +38
245 and 265 tyres, KU39.
Next is sway bars front and rear I'm thinking, getting a terrible knock from my front end which I believe might be a sway bar end link :angry: Then maybe a 1.5 Way and then I'll finally get onto power..
  • 4 weeks later...
Well I had my first track day..
Oil got to 130 deg after 2 laps, and water started to get close to the top of the dial after 3 so I had to backoff and let the car cooldown for 15 mins after every two laps, annoying to say the least!
So next up is a new china radiator + mocal oil cooler, which will require battery relocation and new washerbottle/catch can :)
Vid incoming of my terrible driving.
  • 10 months later...
^^ Agreed, looks great!
Sliding around is always fun, looks like you're getting the hang of it, nothing helps more then practice :) . Then you can work on transitioning between the corners :P
How did you end up going with the radiator and oil cooler?
Bought a 42mm ebay rad and put that in, I have a Greddy Oil cooler + Block sitting in my shed but yet to put it in yet as I'm probably going to sell the car soon and buy an Evo IX.
Temps were fine on that track day although it was only 17 deg, oil sitting at 110 deg after 3 hard laps and water was fine. I'd say I'm going to need the oil cooler for summer track days if I end up keeping the car.
Edited by owen1r
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
