Hey all
So After owning about 8 foresters over the years and recently a toyota aurion as my daily ...(it was cheap) I needed a new daily driver that was a jap wagon and NOT a forester (for once)
Stagea seemed like the only logical choice -Caldina , legnum - not for me..... always loved the older WC34 - as it had the same flavour as the jap forester sf5 that I love so much......But I wanted something a bit newer looking and a daily I wouldnt spend weekends on modding, just drive and enjoy....and with that in mind I started looking at Autech Axis 3.5's with the idea being - non turbo so I wont mod it...maybe change wheels and suspension thats it....
Took one for a test drive, had a look at some more...Then I thought: maybe I can find one with all the hard work done in Turbo - and do small things If I have to....So I found one on Carsales and made a call - arranged to see and test drive Haydn's OM350 - Took for a drive, loved it.
That day I was due to check out another Autech AXIS but I knew what I wanted. I put a deposit down that day.
Im sure you all know the mods but Ill copy paste from Haydn's ad incase you havent seen it!
Here's the details:
2002 NM35 250t RS Four
88,000kms
QX1 white pearl
M35 Dayz bodykit & rear spoiler
Impul ECU
Blitz NUR 3" stainless steel catback exhaust
Heatwrapped Scotty dump & catted mid pipe
Inlet runner spacer
Blitz panel filter
HDi front mounted intercooler
Turbosmart plumb-back BOV
2 x oil catch cans
Transgo shift kit
LSD rear diff (no HICAS)
Tein coilovers
Whiteline front & rear swaybars with HD rear links
Daleobrace front lower chassis brace
Ox Motorsport rear chassis brace
SPC rear camber & toe kit
Hardrace adjustable front upper A-arms
Superpro front caster bushes
350Z 'Track' Brembo gold calipers with QFM pads & slotted DBA rotors front & rear
Gloss black 19" x 8.5" Rota Grid wheels +25 offset
Engine oil cooler & power steering cooler
Scotty coolant bypass & bleed valve
Nismo thermostat
Samco silicone radiator hoses
Boost, engine oil temp & pressure, transmission temp gauges (factory triple gauges also)
HKS OB-Link hooked to 6" Android tablet mounted in factory pop-up screen location
Alpine Double-DIN touchscreen DVD headunit with Bluetooth & Satnav with reverse camera
DTV-B TV Tuner using factory antenna
Brake wire cut mod with switch
Recently replaced O2 sensor, AFM (old p/n), front lower ball joints, front hub bearings, rocker cover gaskets (both), Philips D2R headlight globes, battery, Attessa pump
March '14 rego
Look forward to a Stagea cruise if I have time (new Father)
Dane
Edited by Dane
Welcome mate, you sure picked up a bargain with a lot of good stuff already done.
Plenty of info on here, have a search, and you'll pick up on the most common things.
Enjoy your stay :)
Thanks guys very happy with the car, credit to Haydn, The mods are exactly my style :) I had a forester gt automatic (black one on bags above) which also had a tune to 15psi, the "stall turbo, launch!" feeling is so great to have back. My black foz made 170kw atw - wondering what this beast makes though it's definitely way quicker !
I won r35 wheels on ebay ! Now if only I could find some r35 front seats cheap!
The wheels it already has look so good though.
Good luck with those seats. If you find some they look awesome.
what about these ones, seems like a pretty decent price
http://www.skylinesaustralia.com/forums/topic/436315-fs-r35-gtr-factory-oem-redblack-front-seats/?hl=%2Br35#entry7146391
Edited by lidz
  • 2 months later...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
