Hey peeps,
So, I'm up to my second 5k service and thought I'd do it myself. I've never done one before so I was wondering what is actually done in a 5k service so I can purchase the goods :D
Also, I have no idea on what type of oil to use or anything of the such, so specifics would be great.
R34 GTT (RB25DET NEO)
Cheers :D
https://www.sau.com.au/forums/topic/436381-5k-service/
Ryco z145 oil filter
Ryco z200 fuel filter
Nulon 10-40w synthetic oil.
Clean pod.
Drive.
Would the Shell servo down the road supply that oil? Where do I get the other bits and pieces? Supercheap or something?
cheers
Do you know what spark plugs you have at the moment?
I do not - not sure if gapped or whatnot. I haven't checked.
Edited by RosieR34
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144718
Hey peeps,
Cheers :D
There are so many threads on all this information in forced induction. If you bothered to search instead of being lazy you would find an abundance of information. For someone that has such a high post count you really are a noob. Edited by Pattey21
  • Like 1
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144753
I am very aware of the search feature and the abundance of information. But I prefer speaking with my little tight knit community and getting their opinions- you know, creating discussion and such? After all it is Monday morning.
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144764
Lol
Rob's Autoservice in Dunlop. He will learn you !!
Take Wallet with monies and the willingness to follow instruction and get your hands dirty.....
I think Rob is a bit busy these days - Skywagon and all ! haha
Was going to crack open the YouTube and try my luck there. A lot of people seem to do their own 5k so i thought it shouldn't be that hard(:
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144774
I have heard of the search feature and the abundance of information it has. But I prefer putting in little effort and getting my post count above 2k before christmas would be awesome!
That's what I read.
At the very least have a browse first and have some idea. Starting up new threads about such covered fundamental information just dumbs down the A.C.T section. There is a wasteland thread after all.
Anyway,
I use penrite HPR5 SN grade fully synthetic, good value for money.
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144793
You undo the sump plug (make sure you have something to catch the oil. Whilst draining pull the spart plugs out. When finished draining take the oil filter off and put new one on (rub a bit of new oil on the seal of the new oil filter. Put sump plug back in. Fill up with oil. Really simple. Unless its a GTR because the oil filter is a bitch to get to.
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144802
Motul turbolight is what i use.
Everyone likes different oil.
A bit of moisturising cream on the hands first, it helps to wash off the oil and stuff afterwards.
Do the filter tight BY HAND not too tight or its hard to get off.
Check other fluids while youre there, coolant, pwr steering, brake, clutch, maybe even check condition and level of gearbox and diff oil.
Clean or replace the air filter.
Change the fuel filter.
Clean battery terminals, and check battery fluid levels.
Some of that aircon cleaner is nice, Autobarn i think. Kills all the mould and stuff in there.
Tyres, tread depth, pressure. Make sure ALL wheelnuts are tight.
Have a look at how much brake pads you have left.
Im sure i forgot something......
  • Like 1
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144901
I think Rob is a bit busy these days - Skywagon and all ! haha Was going to crack open the YouTube and try my luck there. A lot of people seem to do their own 5k so i thought it shouldn't be that hard(:
I will help you. :thumbsup:
  • Like 1
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144945
Check suspension and brakes: Tie rods, ends, bushes (all of them) for movement. Shocks for leaks. Uni joints for movement/play. Brake pads for wear, Brake discs for wear, brake fluid and anything wrong with the brakes.
Check Exhaust for leaks, rust
Check tyres for wear (wheel alignment, camber wear)
I use Penrite oils but because I'm broke I use Shell at the moment (so cheap at Kmart).
In the end, you might just end up doing an oil change and not a service.
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7144955
+1 for Penrite oils. I use HPR15, cause the engine is a bit old, so something a little thicker. I don't know what its like for RB25s, so maybe use a HPR10 or 5.
Also I don't know how hard it is to get to the filter on 25s, I have a fandangle filter claw thing (can get one from Supercheap, IIRC it was like $15 or so) that makes them a breeze to take off. On the 20s, its on the intake side, in the worst spot under the intake mani.
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7145069
its under the intake on most cars . Pretty easy to get off.
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7145131
Gotta say, this thread intrigues me...
All this time on SAU and you haven't researched what you need and how to do it?
How do you think I know about these things?
Cooz I says to myself, "Self" I says, "my car is gonna be up for some lovin' in the not too distant future, perhaps I should look into the dos and do nots involved in said lovin'".
"Do I have access to a wealth of knowledge which may enable me to make informed decisions regarding my queries?"
"Yes I do" myself replies, so I then investigate, research and absorb what I can/need to know and act upon it.
Your excuse? :P
https://www.sau.com.au/forums/topic/436381-5k-service/#findComment-7145252
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
