I have seen this in other forums its as helpful as the "one word" thread but still what the hell
So basically you post a picture with the next number, so I'll start with 1 and the next post should have a pic with the number 2 in it, then number 3 etc etc
Edited by gtr judd
https://www.sau.com.au/forums/topic/436474-number-in-pictures/
