  • Replies 98
If the op doesn't bob I will have except the one near the airbox if that helps
Once I have the airbox one I can work out which side I have underneath and make contact in getting the other.
Cheers,
Bob.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
