Gday guys. Trying to sort out all this backfiring with my r33 gtst. Its a 95 series 1. Mods are a pod filter, previous owner added a turbosmart bleed valve, and apparently blew the stock turbo so added an upgraded (or high flowed, forgot what he said) turbo. Has a blitz bov on the piping, but its disconnected (no vac line) and was told its got a blocking plate on it which i may double check tomorrow, but the cars still running the stock recirc bov. The problems i am getting is the car sometimes backfires and can shoot flames after hitting boost and tapping the accelerator etc, and sometimes when i hit the throttle and come on boost it has two or three pops and loses power during those pops, like some sort of misfire. Also like many other people, the revs SOMETIMES drops below 500 or so then creep back up. Any ideas? Crappy plugs/ coils etc? Cheers. Ps the factory boost gauge says I'm doing around 5 pounds but the car pulls hard, would the gauge be reading correctly?cheers.
https://www.sau.com.au/forums/topic/436933-r33-gtst-backfiring-idle-drop-etc/
ohh k lol thought it was psi ;P i feel dumb haha anyway. I am pretty sure still stock ecu, I think the guys basically blown the stock turbo, so went to just jap and told them to give him something better to bolt on! the blitx bov isnt doing anything atm and the stock bov is the operational bov and properly plumbed so thats sorted. and yea hopefully soon will get a tune, any suggestions on a piggyback etc? power fc? ive heard mixed things on many piggybacks to use, whats got the best proven results on my car (r33 gtst)? thanks alot guys!
PowerFC is the only easy/cheap way to do what you want. Nistune is more than capable of handling that power level, but you can't put a Nistune board into a crappy R33 ECU - you have to find a Z32 or R32 ECU and then there are small problems you have to work around. Not worth the pain if you're not already up to speed with it.
So, PowerFC it is.
And, FWIW, don't drive it around on higher than 10 psi with the stock ECU. Bad shit will happen.
ok cool thx. so if the boost guage is reading 5mhgh or whatever it is, is that ok? or should i give the bleed valve a few clicks lower for safety? whats a good price a power fc can be picked up for? i want to find one at a good price so i can then take it to a tuner to install and tune etc. cheers for all the help!
So, PowerFC it is.
I presonally wouldn't touch a PowerFC, they may be cheap, but they're cheap for a reason. People want ECUs that can offer better features, such as doing something if the engine knocks.
true. well maybe for my needs an fc is all thats needed. also, seeing that only real performance mods atm are bigger turbo and bleed valve (will be replaced with ebc soon) when i get an ecu and tune, whats a good boost/ power I can sit at with stock internals, injectors etc? thx guys!
The problem mentioned is not very related to a ECU, Such as the back firing, the down revving under throttle and etc. Those are more related to the differences in the volume of air that the engine had to what the AFM might have sensed.
If aftermarket ecu is on the list, I recommend Adaptronic Plug in R33 ECUs. Plenty of functions and cheaper then most of other options around.
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
