  • 1 year later...
Just had it pointed out to me that my sard reg probably isn't E85 safe. Anyone had one fail? I can only assume that if a lot of you are using a stock RB reg, that an aftermarket one would have a good chance of withstanding problems from E85..
I put the Sard FPR in. I was a bit worried about it at the time hence why i started this thread. Tbh, I wouldn't worry about it too much, It'll be fine.
Like I said, I've had it running straight E85 for a year, no problem.
Had mine for 12months.. Over 10k in kms
Running both 98 and ethenol, no problems
Has been sitting with ethenol in it for quite some time now.. If its stuffed when I start it next month I'll know why
  • 3 weeks later...
Regs don't flow 'Power', they bypass fuel to hold a certain pressure.
If you can run your desired base fuel pressure with the injectors off and pump running, then the reg has enough flow. Stick a larger pump in, and it might not be large enough...
Sorry don't understand that answer. Bought a Tomei Type L hopefully it's sufficient but still interested in a simpler version of you answer if possible
If your fuel pressure spikes too high you need a larger regulator, it is not dependent on the power your making.
Kind of like the size of a wastegate on a turbo. The more boost your running the smaller the wastegate can be as it is bypassing less air from the turbo to maintain that boost pressure.
Edited by Marcus89
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
