Hi guys this is just an idea at the moment not a serious plan but is it worth doing a rb25 swap into a r32 skyline. I have an rb20det at the moments which is fine for now but I was wanting to eventually get a rb25 and rebuild it and put it in my car but is it hard to do and what are some problems with doing it thanks.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/
I have had so many problems, it is so definitely not worth it. i still havent finished and ive been working on it for a while.. i changed it over caz my rb20 was hunting and i had the rb25 lying around so thought after reading it would be easy enough. I have plugs that dont fit, all the looms change. Dont reuse the rb20 loom, this does not work. I should of just fixed the rb20
I dont even want mine road registered so i havent worried about hooking up to body and making speedo or wipers work either.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7158928
We tried reusing the existing wiring and found the injectors we wired up correctly except one were the wiring colours reversed.
You lose VCT from the rb25det as the rb20 doesnt have it
The ECU fried when we tried using the rb20 ignitor box
Just whilst the engines out, change the loom straight to the Rb25det loom, injector loom, coil loom, ecu and ignitor box
youll need to figure out how to wire up the body harness and get the wipers, speedo, fuel pump etc all working.
Another issue i had was the injectors had seized from the engine sitting so long, had to hit them with 12v so they free'd up.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7158966
the wiring colours dont match between loom and 32 plug so youll need to do lots of reading and checking wiring diagrams etc for that to just "plug in". I posted asking for some help on this and even asking someone if theyd do it if i paid and got no answers so it was go through all the wires and figure how they transition however i dont want my registered so i ran an individual power line to the fuel pump and bypassed all of that.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7163041
I not being a smart ass but I did the swap in 2 weekends going from a rb20 with a broken timing belt to a running rb25 using a series 2 rb25, wiring harness and ecu.
I used all the r32 alternator, starter, power steering pump, a/c compressor, engine mounts and harmonic balancer. So it bolted back in as if it was always there then modified the r33 harness using the 32 body plugs (in the cabin) and fired it up and never had an issue, it was my daily driver and everything worked as per factory
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7163355
if i did it again i would have dropped a V8 in it (since its for drifting and would have been a lot less effort).. TBH the rb25 and rb20 are not worth doing up, youd be better spending the money on a 32 GTR.
End of the day its your money and if your up for the hassles and cost then go for it.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7167764
  • 1 month later...
Series 1, i got it running, idles a bit rough but no tune, injectors were seized and hit with 12v to free. need to hook up to ECU and tune.
I am now running all rb20 wiring with new AFM (stock, dont know if mine was causing a problem) and R33 ECU. Have the rb20 coil box still there as matches wiring.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7223070
It's my opinion some people should not got down this path, they're simple not suited to the problems you invariably come across.
Makes no difference if you're swapping a 25 in place of 20 or going for a V8, you will have some dramas along the way.
With all the info available on the net these days, one would expect a straight Rb to Rb swap to be easy but that hasn't been my experience, you need patience and some clear headed pin out ability when it comes to the wiring.
Forget an auto sparky unless you have very deep pockets. Usually you're simply paying him to learn.
You also need to sift through the mass of mis-information given on the net, a LOT is simply rubbish.
Talk to the guys who have actually done the full hands-on swap, not the keyboard heroes.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7224143
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
