For sale are some quality parts I consider surplus after a few changes in direction....
1. GT2860-7's with 400km's travelled, 2nd hand cam (exh) broke and bent some valves, rebuilt engine to higher hp spec's than the -7's.
In excellent condition, includes garrett actuators.
Price; $1500.
2. Axxis Hero wheels, 19/9.5 at +22 offset, They have almost new(400km) 265/30/19 Kumho Ku31's , the wheel pictured has the worst rash,
The same wheels in my avatar, Selling due to finding some LMGT1's.
Price; $1500.
3. R33 GTR specific Apexi PFC with hand controller.
Price; $650.
4. Ti front pipe, unknown brand, Learnt the hard way R34 pipes are indeed longer than the R32 & 33's
Pics indicate its good condition.
Price; $500.
5. Kakimoto Hyper Fullmega N1 cat back exhaust in good condition, front section heat wrapped.
Price; $350.
6. CES dump's and matching front pipe, includes adaptors for lambda sensors.
Price; $300.
7. Jjr coil pac's, where replaced with Splitfires which didn't change the issue.
Price; $200.
8. Std R33 RB26 injectors.
Price; $200
9. Std R33 RB26 Crank balancer/pulley, has travelled 400km, upgrading to crank trigger set up.
Price; $200.
10. Chinese?? GTR hard pipe kit...silicon joiners and hose clamps included.
Price; $150
11. 3in Hi flow cat in good condition.
Price; $75
12. Have a std size R33 RB26 crank,
Good condition.
Price; $250
Misc...RB26 rod's and pistons, also a sleeved block which is cracked through to the water jackets from the head studs.
Offers considered....
Happy to post at buyers expense, pick up is fine too....
PM me on here or text to 0418630718.
Cheer's Glen.
Pm's replied...
Also have 2 intercooler's, 1 from an R33 GTR and the other from an R34 GTR, relatively good condition, pic's if your interested.
R33 int- $200
R34 int- $250
Gday...
The Ti pipe is 70x2 into 80mm, it will fit under the car no problems but is a fraction longer, off the shelf cat back systems will no longer fit without mods...
Hard pipe kit SOLD and dispatched.
    • Don't assume too much when there is a voltage issue....if the battery is flat and the alternator not charging it is easy for the voltage to drop way low at the ECU due to the draw of stuff like coils, fuel pump etc Whatever you see at the battery with the motor off, it should be at least 13.8 with it running
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
