Hey Guys, had a go at this last weekend, was tedious at times but overall went smoothly =)
The black has really given the interior a fresh look and im pretty happy with the results ! was worried the Metra kit would look a bit tacky but it actually looks fine. =)
What do you guys think?
https://www.sau.com.au/forums/topic/437441-metra-kit-install/
Sweet work. My dash looked the same when I installed the double DIN JVC head unit to replace the crappy stocker with a jap pop CD stuck inside. So much to pull apart... Lucky mine is a non Bose so just all went back together smooth as.
I think it looks good, but I don't think you did a search nor asked on the forums about the Metra kit.
A simple question would have resulted in you knowing beforehand that not only do you now have very crappy/tacky rubber buttons, but within a short timeframe your a/c controls will fail and you will have to buy an oem kit anyhow.
Metra kits are junk. Fullstop.
  • Like 1
All controls thus far are working fine, how many metra kits have you heard of failing? And what causes the failures? The buttons are rubber but i don't think it detracts from the overall finish and I'm actually very happy with the results over the factory look.
I also think not everyone has an unlimited budget.. The metra was half the price of the oem and the touch screen stereo has gps and all the mod cons but its no brand name either.
I am happy to take my chances ( to late now i guess ) and will 100% report back here if i have ANY problems with the controls.
They came in 90% of NM35 stageas and the very very very basic V35 sedans, same dash and everything.
I agree with nightcrawler. Metra kits are hideous. Spend the time and the bit extra and get an OEM one.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
