You may need to pull it off then to work out what it is. Does it really matter? Just tune it. :P
Did you check from underneath for the tag?
It is pretty old, most turbo's that size have anti surge housings these days.
Looks a lot like the housing most typically used on GT3071R but as others have said, check the core (solid bit between the two housings) for a serial number <br /><br />Sent from my GT-I9505 using Tapatalk<br /><br />
If you can see under the inlet boss/hose on the front of the compressor housing look for an AR number ie 0.50 A/R .
AFAIK only GT3071Rs used that housing in that AR ratio with the large inlet boss .
The unknown is if someones made up a non standard bitzer and the only way to tell is to remove and pull the housings to measure the wheels .
Does it have a Garrett GT30 IW turbine housing on it ?
A .
Does it have a
A .
It says A/R 67 or possibly A/R 70 from memory.
Not sure if it has a Garrett GT30 IW turbine housing on it, don't even know what that is TBH, lol
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
