  • Replies 103
dun tell me only the leeches have been downloading.....
I have had it running since last night, and I have only downloaded 200Mb and uploaded 300Mb....
Comon people, make sure you leave it open after you finish downloading so the rest of us can get it!
ok, that gtr.org.uk site is and has been ****ed for ages. Don't bother trying.
Manwhore is a champo. He gave me a copy of both manuals. It's also posted up on the internet on his site as well. Forget using bit torrent and all that.
Manwhore i read your thread about the SYB (Start ya bastard). Any news?
Its a pitty the R32 engine manual isn't as good quality as the R33 engine manual.
If any one needs a copy I have them both also.
The R32 is around ~25mb from memory and the R33 is ~149mb.
The Max you can dload it from me is around ~12-13kb/s through a locally hosted webserver on my end.
Is it all right if i can have both the manuals?
I am living in Melb. I can pass you a CDR if you want...
What do you reckon?
Cheers.
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
