  • Replies 103
dun tell me only the leeches have been downloading.....
I have had it running since last night, and I have only downloaded 200Mb and uploaded 300Mb....
Comon people, make sure you leave it open after you finish downloading so the rest of us can get it!
ok, that gtr.org.uk site is and has been ****ed for ages. Don't bother trying.
Manwhore is a champo. He gave me a copy of both manuals. It's also posted up on the internet on his site as well. Forget using bit torrent and all that.
Manwhore i read your thread about the SYB (Start ya bastard). Any news?
Its a pitty the R32 engine manual isn't as good quality as the R33 engine manual.
If any one needs a copy I have them both also.
The R32 is around ~25mb from memory and the R33 is ~149mb.
The Max you can dload it from me is around ~12-13kb/s through a locally hosted webserver on my end.
Is it all right if i can have both the manuals?
I am living in Melb. I can pass you a CDR if you want...
What do you reckon?
Cheers.
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
