Ok this is a flight of fancy more than anything else but does anyone know of a successful dual clutch gearbox transplant into a Skyline? It would be a major undertaking with a lot of custom work (read: cost prohibitive) but would be very interesting to see nonetheless.
I had a quick look at eBay and you can get some second hand Porsche PDK units from around $5k in the US. Used DSG boxes from VW seem to start at around $3k - not that those would take 300rwkw without some serious work.
But yeah 200ms shift times would be sweet :)
https://www.sau.com.au/forums/topic/437774-dual-clutch-gearbox-into-a-skyline/
This will eventually have to get to the aftermarket (ie, some sort of semi-universal programmable control system for 2nd hand DSGs). But I don't think it is here yet.
But, there are very very few DSG type gearboxen that you would consider taking on board after someone else has used it. There is no way on God's green earth that I would ever own a VAG DSG out of warranty (in fact, I wouldn't buy any VW or Audi type vehicle at all, let alone a DSG one). Most other manufacturers dual clutchers have shocking histories of random and expensive failures. The only ones that would be desirable, from the lack of sudden death viewpoint, would probably stay expensive.
It would be good to see, but I think it would be hard to get an adapter or custom bellhousing made to bolt to the RB block. I'm not sure how the gearbox splits the input to the 2 shafts, so might be a bit busy in the front of the gearbox. I'm sure its doable, but you might have trouble with boxes that are rear mounted and get drive from the engine through a prop shaft.
WIthout having ever seen one out of a car, sitting there available to have a bit of a look at, its hard to say. Would probably end up costing a bit if you were the first to try it, but if an adapter or modification to an existing box was mass produced it might bring the price down to something which would make people think twice
As above, I would be a bit sketchy about using a VW dual clutch. My girlfriends VW Polo is on its second DSG after a re-call and it shudders in 2nd on a slow takeoff which I think was half the reason they were recalled (not sure if it was the cause of that girl whose dsg failed on a motorway and was killed, but the shudder is a common problem)
Maybe the Nissan GT-R box would be good but it wouldnt be cheap and has the prop shaft input.
Edited by 89CAL
I remember watching a doco on the GTR, and they said stress test every DSG box that they fit on a car on a special machine to make sure it works perfectly, on top of the strangest handbuild production methods. They stated they are the only manufacture in the world to do so. The only ones I have heard of breaking are the early model ones that were incorrectly "launch" controlled, and new ones that have to put up with over 1000hp of abusive driving. Aside from that, I have never heard of one ever breaking on a unmodified car.
Though how would you even get it to work with the RB? The design is completely different from every perceptive.
Thanks for your input everyone. It pretty much confirms what I thought - would be neat but way to exxy to be feasible at the moment.
I think there's some hope though, if you look at the dual clutch gearbox supplier list on Wikipedia there's heaps in production. No doubt in a few years there will be more to choose from. There's something in the idea of mating a 15-20 year old RB to the latest in gearbox tech :)
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
