ALL PARTS Located in the south east of melbourne 3150
Happy to post at buyers expense
I can text you photos if the parts for sale via SMS
0401035221
RB26 GTR push type gear box
Was working fine when removed
$400
AME TRACER
18x11 +10
Wheels are made by enkei
Same wheels used by cyber evo at WTAC
Small mark on the wheels nothing major
$2000
RB26 aftermarket camshafts
The camshafts came with a engine I bought is Japan, custom grind from a workshop in Japan
Have larger lift and duration but don't need to modify the cylinder head for clearance of the lobes
$300
R34 GTR z-tune fibreglass bonnet
$100
R34 z-tune front fibreglass gaurds
Only test fitted still new
$300
R34 GTR/GTT wide body rear fibre glass gaurds
Only test fitted
$300
RB26 M's pod filter
Suits cars with twin AFM
Fits all GTR'S
$60
R33/R34 standard shocks and springs
Used to pass roadworthys and defects
Actuall drives really smooth
$100
RB26 TPS
Brand new from nissan never used
OSGIKEN pull to push converter
Used but works perfectly
Suits RB gearboxes
$100
R32/R33 GTR Power FC
no hand controller
Works perfectly
$700
Racepace adjustable camgear a
Used but work perfectly
$50
V8 supercar spoiler
Fitted to a R34 GTR Boot lid with crush tube inserts
Paited black with 'Nissan' logo on the spoiler, genuine V8 super car spoiler came of a VX HRT CAR, carbon fibre blade etc painted black
$600
RB26 Conrods
Complete set, came out of a r34 GTR engine
$50
All parts located in the southeast of melboure
3150
I can send you a message with photos of the parts for sale
0401035221
https://www.sau.com.au/forums/topic/438112-gtr-parts/
R34 mines ducktail rear spoiler
Super rare, came off a RH9 drag car in Japan
$600
R34 GTR/GTT coupe carbon rear boot lid
Has 3 small holes drilled in it for the super car wing
Easy to repair
$200
0401035221
https://www.sau.com.au/forums/topic/438112-gtr-parts/#findComment-7182827
Hey mate in regards to the cams, does there need to be any replaced valve springs etc.. I know you said no head modifying required but just wanted to check because obviously it would be buying them with a bit of guess work ;)
https://www.sau.com.au/forums/topic/438112-gtr-parts/#findComment-7199342
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
