Hi there guys, I'm from Spain and i got an Euro S13 swapped with an rb25det neo coming from an skyline r34 gtt sinister with around 12.000 miles on it
The engine is a bit modded with an hybrid gt30 turbo with t25 housings spooling really fast, got a Freddy front face intake manifold rewelded with tig welder and Q45 throttle body, running a LINKecu G4 Plug-In as an electronic management system with 2.5bar map sensor and IAT, intake...exhaust...brakes...wheels...and other things that hasn't so much importance on this thread
The head and the bottom end are stock but im changing the timing belt with a full set of gates racing and i profit to get the head out and get fully checked and mounting a metallic 3 layer headgasket as im boosting at the limit of the stock headgasket 1.2bar and arp headstuds
Got an issue with the arp headstuds as the website show two kits for the rb25det, 202-4301 and 202-4309, emailed arp and they can't tell me what is the correct application for the rb25det neo and gaved me a calculator sheet like that to fill, my knowledge doesn't go too far to get this measurements and anyway i don't think that this will be necessary as many people run arps on his neo and dont think all those people has do this
Somebody can give me some light on this?
Thanks, cheers and sorry if my english isn't enough good
Are you just chasing sizing on the bolts to confirm they are for neo?
If thats the case, im suprised that ARP cant tell you. Perhaps getting in contact with an engine builder who does alot of RB engines can help
Otherwise you could probably just dummy fit the head with 2 studs in and see how they fit and make sure the nut has enough thread to clamp the head to the block
Also with the link G4, if you have a 2.5bar map sensor then it maxes out at 1.5bar of boost. Not sure if its an issue but keep in mind that the 2.5 bar is absolute pressure not gauge pressure
Didn't bought any studs yet, just asking arp for wich its the correct application for the neo, they told me to fill that measurements sheet and send back as the two kits are different length and not interchangeable, im surprised too that arp needs this measurements to tell me wich its the correct application and i can't take because my knowledge doesn't reach that level and i don't have the necessary precision tools to make this measurements
Your idea may work but buying the two kits like a dummy to see wich its the correct ones doesn't seems good for me not talking about the money waste
Just wanted to know if someone here has mounted arp headstuds in his neo engine to know wich ones has bought and if they worked fine
I know the map sensor its 2.5 absolute pressure and i just can boost to 1.5 as the map can't read more of that, im doing this because i was boosting 1.2 with stock headgasket and if im not wrong the limit on the stock headgasket its 1.2 and my idea its get it to 1.4
Thanks for answering and for your help
Edited by Eclipsado
The stock headgasket and head bolts can take 1.5bar(21psi) pretty confortably as alot of people are still retaining the stock hg and bolts in there rb25 and neos so I wouldnt be very concerned about that.
Yuh, don't open the engine unless you have to. 300+ rwkW on an unopened Neo is easily doable.
Thanks for the replies, my rb its at this moment at 397hp on the flywheel and im looking for more, i'm gonna upload the dyno graphic when i get home for share it
i'll appreciate all your replies but none is helping me, can we focus on the arp headstuds issue? The head is out and being on the machine workshop at this moment so the replies telling me not to change the hg not to open the engine are useless anyway as i said i'll appreciate your replies
I'm 99.99 percent sure there is no difference between neo and non neo head bolts \ studs.
Looking at the 2 part numbers, the one ending in 9 has a slightly higher torque specified.
I would buy what ever is cheaper.
But I wouldn't. I reused my head bolts for my rb2530 with 295rwkw, so do whatever.
  • Like 1
Thanks dude for such a good reply, that's so useful for me
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
