Hi folks,
Up for sale I've got the following bits;
1; New Apatronic select (eSel027) plug and play to suit R34 GTT, with vac lines etc. Only opened to look, spec list can be found there http://www.adaptronic.com.au/product/esel027/ - Asking $1,000.
2; A set of 17x9 +22 Advan SA3R with 235/45/17 Federal 595ss - fronts have decent tread and rear are camber worn quite badly, comes with centre caps. Asking $650.
3; Apexi Delta fin turnflow FMIC with engine bay piping, in good condition with joiners and clamps, could use cleaning prior to use. Asking $500.
4; Bosch 044 fuel pump, worked fine before removal. Asking $100.
Price is negotiable on these, can assist with postage at your cost or arrange a meet halfway/deliver for extra $. I'm located in Northern Suburbs Melbourne.
Either PM or SMS on 0498 650 167. Pics to come, or fire me a SMS and I'll MMS pics back.
Cheers
Grant
Bumpity!
Can't upload pics thru the app without crashing. So, SMS me for pics.
Again, I'm negotiable with the pirces as I'd like to move them on.
Hi folks,
1; New Apatronic select (eSel027) plug and play to suit R34 GTT, with vac lines etc. Only opened to look, spec list can be found there http://www.adaptronic.com.au/product/esel027/ - Asking $950.
2; A set of 17x9 +22 Advan SA3R with 235/45/17 Federal 595ss - fronts have decent tread and rear are camber worn quite badly, comes with centre caps. Asking $600.
3; Apexi Delta fin turnflow FMIC with engine bay piping, in good condition with joiners and clamps, could use cleaning prior to use. On hold.
4; Bosch 044 fuel pump, worked fine before removal. Asking $90.
Cheers
Grant
Price adjustment time!
Want them goneski! As usual, will entertain any reasonable offers!
You buy!
Aww man I wish I didn't just buy seats otherwise I would be snapping up that ECU. Retail for $1499 and even with a hypergear discount it would still be $1099
Why u no laybuy?!
Why u no laybuy?!
Aw, poor you.
Can always save up and buy the ECU, or sell the seats :P
whaTever happened to josh...he wanted tris for ages...
I contacted him and he said he was broke.
Photos of the cooler/ price to ship it to 2256 nsw thanks
Cooler is on hold for a mate, will update of its status later this week.
Sorry for late reply - had to talk to mate.
Want a set of BC BR's for a 33 and cash your way?
Um, what am I going to do with something I don't want and have no use for it?
Hahaha sit it in your garage?
:yes:
I've enough shit all over my garage so I'll pass.
Put them up for sale saying you want the ECU.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
