Yeah in uploading some pics now to chuck then for sale. :)
Fingers crossed
Good luck!
Hi folks,
Up for sale I've got the following bits;
1; New Apatronic select (eSel027) plug and play to suit R34 GTT, with vac lines etc. Only opened to look, spec list can be found there http://www.adaptronic.com.au/product/esel027/ - Asking $800.
2; A set of 17x9 +22 Advan SA3R with 235/45/17 Federal 595ss - fronts have decent tread and rear are camber worn quite badly, comes with centre caps. Asking $400.
4; Bosch 044 fuel pump, worked fine before removal. Asking $50.
Price is negotiable on these, can assist with postage at your cost or arrange a meet halfway/deliver for extra $. I'm located in Northern Suburbs Melbourne.
Either PM or SMS on 0498 650 167. Pics to come, or fire me a SMS and I'll MMS pics back.
Cheers
Grant
Just cos I'm in shit mood lately, I'M REDUCING PRICES.
Plus I've got Kakimoto mild steel exhaust to suit R34, asking $100 for it.
Take them away.
It's just the pump itself, came off my R thinking it's dead but the issue turned out to be useless wiring done by a workshop.
i dont know if i can be arsed farking about with all the bits mang...
Since you're going to farking about with turbo, may as well go for the whole hog? Can always pop in Scotty's and take things there ;)
scottys time is a lot more expensive than mine mate lol!
Just feed him a slab and I'm sure he'll be flexible afterwards :P
lawl! he has a family to support and shit man... can t feed kids booze!
or can you????
Yeah, they'll be right!
Or feed them some snags to sweeten the deal.
Adaptronic ECU is SOLD pending money clearance.
Wheels, fuel pump and exhaust still available.
Cheers
Money.
Adaptronic SOLD and posted.
Everything else still up for grabs, buy them!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
