Warning Name
Warning Description
Warning Points
Off-Topic
Any off-topic posts made.
2
Chatting
Any chatting in areas that do not allow chatting (such as the for sale area)
3
Trolling
Attempting to get another member to 'bite' so as to argue with them
5
Trader Rating Abuse
Anybody not using the trader rating system properly
5
Pr0n
Any adult material posted on the forums
7
Personal Attack
Name calling, threatening - anything which is aimed directly at another member with an intent to cause harm
10
Once you reach warning level 20, you will be banned for 14 days
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-895925
how does one know if they've been given a warning? I assume email, but just checking that you do get notified of them. Is there a way to check my personal total/tally of warnings?
...And 99% of users (everyone without any forum authority) have these links to warn and view with no purpose but to be told that they don't have permission. Or is it just so everyone's aware of warnings?
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896225
I was given a warning in the QLD events section for mentioning another car club/forum.
It wasn't for mentioning another car club/forum Matt...
It was for trolling... See above for the description of trolling...
You've been asked / warned before about this exact thing so don't play dumb...
Happy to talk to you on MSN about it...
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896508
yes you will be notified by PM if you are warned....its just a system to try and keep things under control....if you accumulate 20 points you get banned automatically for 2 weeks.
Is there a use by date with the warnings? I dont think its totally tragic if you accumulate 20 pts over 18 months to 2 years for example.
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-896963
Ok,
I dont agree it was trolling...
Will have a chat in private mate.
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-898779
Who administrates the administrators ??
Moderators do. We recieve warnings just like the rest of you.
Regarding checking points - you can click "view your warnings" under the Quick Links menu ^ up there.
This is just going to be a fair system for people instead of mods personally PM'ing somebody twice about the same thing etc... just helps us keep up to date with it.
Regarding the links - I will mod that so that only the mods who mod that section can see it.
Thanks - any other q's, post em here.
Christian
https://www.sau.com.au/forums/topic/43838-warnings/#findComment-899149
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
