Thinking about buying a r34, two door needs some work, Up for new tyres soon, Front grill is missing, what would you pay for it? its not bad in person, Something i might want to get for the right price and clean it up. but what do you reckon? its something i have been looking at for a while cant really find a r34, for under $10,000 this is under, but i needs some work im thinking atleast $1,000 - $2,000 + New tyres, front end lights , not to much needs done 98k on the clock i have a feeling it might of got wound back Thanks, how much would you pay for this? Im looking around for rough prices.
5G3HBo5.jpg?1
Edited by Bossramsay
It's obviously an R33, just FYI
Hmm that's why I also posted this.. He tolled me a r34 I had a feeling it was something different, I was going to pop the botnet and have a look didn't want to be rude though. And I had to be somewhere ahah, didn't have time.
So u clearly have no idea what you are looking at if you didn't even know it's n r33.
I suggest you do a hell of a lot of research before even going to look at another car
  • Like 1
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
