  • Replies 40
Posted Images
There's an oring behind that bolt. theres oil in there fot the vct to work.
Check it out and replace it.
I cant see hiw overfilling it would damge it, how much overfill are we talking?
So its a pretty serious build? Omly reason I ask is I can see a bolt blocking off a small coolant line in the photo ;)
I doubt the leak has anything to with revs or overfill. Its just a leak.
no seal between the bolt and the cam. Should have the bolt with a washer behind it. Then a spring and plate with o-ring on top of the bolt. Ive had that one off quite a few times when building my engine
Id expect a little bit of leakage past the bolt but nothing major. How come the cover is off?
The neo engine has a different vct setup that uses an oring behind a bolt to seal, which is what I was thinking of.
Pre neo is different as 89cal pointed out 2and the image I posted shows that.
You are missing the cover and the seal.
wait you're missing the cover, spring, seal and those 4x 6/8mm?mm bolts
that's why it looks funny, also if that's the case how does your VCT function properly? I'm sure that spring in there to shift the cam sprocket
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
