I saw 900 degree manifold temps regularly at the track, all with a beanie on. The car has done 6 hard track days and daily driving for many years without issue.
As long as the CHRA is water cooled you should be fine.
Thanks for clearing it up. When I baught my beanie off hpiab they said remove it after hard driving and whilst racing to reduce the risk of damage to bearings. I thought why sell me that if it Can damage the turbo.
Whats the go with HPC? when I had my manifold and housing done I really couldn't tell the difference, I mean even if temps are down
1000c to 800c for example, its still bloody hot, retaining that extra heat might even cause the manifold to crack from the inside
out?? Maybe on a track car it sounds plausible but on a street car things wouldn't get hot enough??
Aparently beanies can lead to internal bearing damage if left on and raced with. No idea how. Hpc coating increases thermal efficiency in the turbo which leads to better response. Plus if you hpc coat it silver the chicks will flock... hard. But in all seriousness when I do go a steampipe manifold ill be hpc coating the manifold and turbo housing. Looks good, doesn't get that rusted look from heat, serves a purpose.
This. Just do it and rest assured it's an asset to your build. I've always HPC coated my exhaust components (if the wallet permitted I'd do the entire system ;) ) but my turbo manifold, ex housing and dump pipe/wastegate plumb is all coated. Granted, it is still hot (but greatly reduced) and you can feel that under the engine bay... but consider this... what would it be like without it? Whilst off, definitely beneficial if you can afford it.
Edited by Reflector
But he already has a beanie, so it's a total waste of cash. I would only ever recommend it for mild steel exhausts to prolong their (short) life.
DEI Beanie and DEI Ti wrap the dump (for stainless) is the best shield against heat I have found so far, and I have used most other styles of heat barriers.
Im not saying it for heat shielding. im saying to hpc coat it to retain the heat inside the turbo exhaust to improve thermal efficiency. Yes it helps shield heat but im aiming at the heat retention in the turbo. i was running a turbo beanie untill a poorly made oil line burst and filled it full of oil. now it wont stop smoking. its like i have bob marley under my bonnet.
Hmm iv hit a wall! I bought what I was told was a gt3076 .82 rear but it does not seem to fit the wheel?!?
Here are some pics. What have a bought and maybe my turbo isn't what it should be?!?
Do yourself a favour and ignore what the tag on the core says for a moment... Measure the turbine at its largest diameter and see if its 60mm or 56.5mm.
ARTZ had a turbo from a reputable resaler which was labelled a 3071, but when we measured up it had a 56.5mm turbine and a 76mm T04S compressor. It was more likely they had rebuilt it and simply neglected to update the tag. Or built a custom turbo from whatever they had around... Who knows.
Its possible that its for a 35R, as the housings are identical on the outside. You should still measure your turbine though.
Once you measure the turbine you will know if you A: have the wrong turbo for that housing, or B: have the wrong housing for that turbo.
You must measure first.
Edited by GTScotT
True: the photo's clearly show its wrong. SO, the task is now to work out what housing he actually needs and who's responsibility the wrong housing is.
In A: the seller did nothing wrong and OP needs to wear it or ask nicely to return, in B: seller needs to give OP a refund as he misrepresented the product.
Edited by GTScotT
Highly likely a EWG housing for a GT3582R , probably the easiest thing is to measure the ID of the housing and if it comes out a little over 61mm that sort of gives the game away . A GT30 turbine from memory measures ~ 54.9mm at the exducer (outlet diameter) so a matching housing would be that plus clearance .
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
