Hi everyone,
I'm after these tail light reflector covers, but cant find them for sale anywhere on the net. also none on yahoo auctions at the moment.
wondering if anyone know where to get them from.
I've seen a few different ones, but they don't all come down and meet the bottom line of the window and that is specifically what i want.
I would really prefer to get the covers, rather than vinyl wrap because I would like to get them painted same color as the car.
And as for takeros and freeway dolphin I found one US website that sells them but from the pictures they are look like the shorter ones and don't come all the way down to the window line.
I specifically want the ones that come all the way down to the window line.
They are Takeros series 2 tailight covers, the carbon fiber ones:
http://autostyle-usa.com/?pkey=item_info&i_code=TAK24121840002&maker_url=takeros
The series 1 came halfway down, the series 2 is to the window (hard to tell with the black car in the pic) I can confirm as I have seen these on the silver full takeros kitted m35 that was being sold in VIC last year.
However for the price they ask for them you could get them made locally - or plastidip/vinyl wrap as Scotty & Lakes mentioned, inexpensive and easily removeable.
If you want to go genuine maybe ask someone like Jesse Streeter what he would charge to get you a pair if Takeros still make them?
Edited by Dmyze_
Had a look and they are still listed on the Takeros website and you can get them in FRP for Y12,600 ($135ish AUD) - so you could get them in via streeter or IM, if you do let me know the total to your door, I'd be interested to know!
Edited by Dmyze_
The link you posted for the autostyle website is not the full length ones I'm after, as you can see the full blinker lens, and the blinker lens extends up past the window another 3 inches or so.
I will check out the takeros site in a few hours. If they are available at that price plus shipping, I will gladly purchase.
Hmm, I swear they are full length, but I see what you mean, In that picture I always assumed the blue sticker was on the body not the window, if you go by the lens it does look like you may be right, however why would they have two same length garnishes for sale?
Regardless I did see the full lengths on the M35 I mentioned, and it was all Takeros (looked almost identical to the silver display car on their website without the decals).
Good luck with the search!
sometimes it really looks nice)
Compare before and after:
handcrafted in Vladivostok
http://www.drive2.ru/cars/nissan/stagea/stagea_m35/ivano-92/journal/688125/
Edited by Erop
Possible that different 2 sets for sale maybe because 1 is fibre glass/plastic and the other carbon?
^ I thought of that orginally but the Takeros website states that both the V1 & V2 are availible in FRP/Carbon and lists prices for each.
Nice! Just need to learn to read russian? I think making the covers look like an extension of the glass looks better than matching them to the paintwork.
Likewise, I didnt really think the white looked all that good - but that looks quite menacing in black!
i looked on the takeros website, but for the life of me i could not find the longer ones.
if its not to much trouble could you post a link please?
  • 1 month later...
Off cut of vinyl (free), hairdryer, couple of hours on a rainy day. Easy DIY & removable if you want a change.
I did mine years ago & still looks as new. A bit of polish brings it up nice & shiny.
I've now purchased a second set of tail lights , I already have the lens removed. I'm going to do an LED patern inside for the tail and brake lights. And I'm going to get the lens' professionaly painted to match the color of the car so now I have no need for the covers.
I paid $150 for a full set of tail lights, So realistically I have a spare set and it is probably cheaper then buying the covers.
So the set I'm now modifying will have LEDs in them and top half painted silver to match the car and also the section around the reverse light will be silver. And my stock ones are staying as is internally but painted black on the top half.
This way I have a spare set and can mix and match when I want.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
