Hi everyone,
I'm after these tail light reflector covers, but cant find them for sale anywhere on the net. also none on yahoo auctions at the moment.
wondering if anyone know where to get them from.
I've seen a few different ones, but they don't all come down and meet the bottom line of the window and that is specifically what i want.
I would really prefer to get the covers, rather than vinyl wrap because I would like to get them painted same color as the car.
And as for takeros and freeway dolphin I found one US website that sells them but from the pictures they are look like the shorter ones and don't come all the way down to the window line.
I specifically want the ones that come all the way down to the window line.
They are Takeros series 2 tailight covers, the carbon fiber ones:
http://autostyle-usa.com/?pkey=item_info&i_code=TAK24121840002&maker_url=takeros
The series 1 came halfway down, the series 2 is to the window (hard to tell with the black car in the pic) I can confirm as I have seen these on the silver full takeros kitted m35 that was being sold in VIC last year.
However for the price they ask for them you could get them made locally - or plastidip/vinyl wrap as Scotty & Lakes mentioned, inexpensive and easily removeable.
If you want to go genuine maybe ask someone like Jesse Streeter what he would charge to get you a pair if Takeros still make them?
Edited by Dmyze_
Had a look and they are still listed on the Takeros website and you can get them in FRP for Y12,600 ($135ish AUD) - so you could get them in via streeter or IM, if you do let me know the total to your door, I'd be interested to know!
Edited by Dmyze_
The link you posted for the autostyle website is not the full length ones I'm after, as you can see the full blinker lens, and the blinker lens extends up past the window another 3 inches or so.
I will check out the takeros site in a few hours. If they are available at that price plus shipping, I will gladly purchase.
Hmm, I swear they are full length, but I see what you mean, In that picture I always assumed the blue sticker was on the body not the window, if you go by the lens it does look like you may be right, however why would they have two same length garnishes for sale?
Regardless I did see the full lengths on the M35 I mentioned, and it was all Takeros (looked almost identical to the silver display car on their website without the decals).
Good luck with the search!
sometimes it really looks nice)
Compare before and after:
handcrafted in Vladivostok
http://www.drive2.ru/cars/nissan/stagea/stagea_m35/ivano-92/journal/688125/
Edited by Erop
Possible that different 2 sets for sale maybe because 1 is fibre glass/plastic and the other carbon?
^ I thought of that orginally but the Takeros website states that both the V1 & V2 are availible in FRP/Carbon and lists prices for each.
Nice! Just need to learn to read russian? I think making the covers look like an extension of the glass looks better than matching them to the paintwork.
Likewise, I didnt really think the white looked all that good - but that looks quite menacing in black!
i looked on the takeros website, but for the life of me i could not find the longer ones.
if its not to much trouble could you post a link please?
  • 1 month later...
Off cut of vinyl (free), hairdryer, couple of hours on a rainy day. Easy DIY & removable if you want a change.
I did mine years ago & still looks as new. A bit of polish brings it up nice & shiny.
I've now purchased a second set of tail lights , I already have the lens removed. I'm going to do an LED patern inside for the tail and brake lights. And I'm going to get the lens' professionaly painted to match the color of the car so now I have no need for the covers.
I paid $150 for a full set of tail lights, So realistically I have a spare set and it is probably cheaper then buying the covers.
So the set I'm now modifying will have LEDs in them and top half painted silver to match the car and also the section around the reverse light will be silver. And my stock ones are staying as is internally but painted black on the top half.
This way I have a spare set and can mix and match when I want.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
