For sale is my 1998 40th Anniversay R33 Gts-t Skyline, 5sp manual
$13,000
Will consider reasonable offers.
This car is in absolutely immaculate condition inside and out, serviced every 5000kms.
Reason for sale - I bought this car last year before knowing I'd be moving to the beaches. I love it, but it doesn't suit my lifestyle ( i.e fit my surfboard! )
Very few modifications:
- 3 Inch Turbo back exhaust
- SBC boost controller - have always run car stock at 7psi
- Tein coil-overs
- Short shifter
- Apexi Turbo Timer
- Kenwood Head Unit
- Bluetooth handsfree, USB (front port and cable in glove box), Aux, CD Player, Digital Radio
- 4 Speaker Stereo - 6 Inch Pioneer splits in the front, 6 Inch 3 way Kicker speakers in the rear
I recently replaced all 4 tyres to pass Rego in December, and comes with one spare (was cheaper to buy 4 tyres than 3).
Feel free to call for more pics or to organise an inspection.
Cheers,
Ryan
0401 487 434
Located in Newport
[email protected]
Edited by rthom009
Haha nah man, this is legit..
I've got the papers from when this car was imported, and know how long the previous owner had it.
If you saw the car in person, you can tell the kilometres are accurate, it's in mint condition..
I read online somewhere while ago that they have the 40th logo embroidered into the seats, slightly different front bumper, gtr spoiler is optional and skyline strut brace...
Not sure if what I read was accurate or if someone on here can verify...
Nice looking gtst but good luck with sale :)
  • Like 1
Yep, has the 40th logo's embroidered, different front bumper (I think), and front / rear braces..
Cheers!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
