i am what you would call a newbie.
and i was simply just wondering to convert my skyline to e85
what would i have to do ?
cheers, sorry if its the wrong place.
Are you after power, or just to convert to e85? There are plenty of off the shelf kits available to simply change the injector pulse duty for running ethanol in any vehicle, but it isn't like what most turbo guys run for maximum power. You really need a standalone ecu for that.
It is highly likely you wont do an emissions test, just a sound test and inspection.
Just quieten the exhaust up, enclose the pod filter (if you have one) and make sure nothing vents to atmosphere.
DECC inspection needs to have factory items fitted. They generally take pics of the car when pulled over, when it goes for the inspection, and the on a database with stock engine bays.
Back when I had my DECC test the inspection guy had a checklist to tick, a quick glimpse I could see
He even had to draw a diagram of the exhaust, drawing all mufflers, the cat and how the exhaust ran under the car.
Ive done 3 DECC inspections and passed with a custom 4 inch exhaust and an 800hp motor. Pics were taken on the rd and taken at the inspection, as long as you dont change "viewable" items between pictures taken its ok.
As long as all aspects are legal (noise, plumbed back) you will be fine.
Correct, high flow cats themselves are not a defect. To pass emissions you need a Euro 5 cat with 500+ cells and a really good tuner.
My 500 cell cat and my one cell cat are identical from the outside so even if they took a pic on the rd and at the inspection they would see the same thing.
As for noise my 4inch turbo back was 88db with some minor "modifications".
