Hey guys I own a 1991 R32 GTR I recently just put HSD Monotube coilovers on. I currently have 18x10 +18 Work XD9's and the guards are not currently rolled but will be soon. I max'd the coils front and rear and the front were about 323mm from the center to the top arch and the rear is 330mm from the center to the arch. Now I know of the consequences of running a GTR to low, Bump steer, CV boots and the drive shaft being on an acute angle and loosing HP. The answer I can't find is at what height this becomes a problem, I like the look of the car running 330mm front and rear for height just wondering if you guys think this is to low and the following problems will occur, Thanks!
https://www.sau.com.au/forums/topic/439378-r32-gtr-hsd-coilovers-what-height/
Skdneykid used to say that 350 front 340 rear is about as low as you could go before it all went to poo (and that requires a bunch of adjustable bushes or equivalent to align), but it sounds like you're going for a look not for performance, right?
Really wow I thought it was closer to 340 on both, and I'm after best of both worlds. I like the look of having a lower car but don't want to loose performance, I might try to get away with 340/340 and see how it drives
Fair enough, but I think that setup may make the GTR understeer more than it would at 350f 340r. Remember that front guards have a larger opening to deal with the turning wheel, so you would expect to have a larger number at the front.
The problem with the HSD's is that you can't really get close to 340 front or rear, the highest I have gotten mine (Although a GTS-T, not sure if GTR coils have the same issue) is around 330 eye brow height. Although I have a bunch of adjustables to compensate ;)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
