46 minutes ago, Anonymouse said:
Aussie post - be at your front door when you get home
if I haven't been past before then
It's coming to work...
Feel free to come around and have a sticky when it arrives... you know. Work related..
15 minutes ago, ActionDan said:
That looks to be in good condition, was it new or second hand?
Pics of it fitted (to another car?)
Second hand, been resprayed to black. I'll have to respray it again....
This is probably the most you will find in terms of other pics
Oh also went go karting on the weekend for the first time in aaages for my bucks party.
Used to do a hell of a lot of Karting when i was younger, apparently i've still sort of got it. Set the fastest lap of the week, and was within reach of the lap record, not bad for my first time at that track! Maybe if i wasn't so fat i could push for it. Ah well, look forward to heading back again!
3 minutes ago, RBN1 said:
Nothing better than the feeling of carrying a 25 year old explosive device in the cabin.
How much do they go for these days anyway?
got it for $20 or something lol
  • Like 2
