Hey guys,
I'm currently not daily driving my car, it sits in the garage trickle charging and I probably drive it once a fortnight and when winter comes it will probably be less.
My question is will I have problems with the fuel going stale? I filled up about 3 weeks ago and still have the same tank. How long before you start to have issues?
https://www.sau.com.au/forums/topic/439550-stale-fuel/
From what I've read, the smaller the amount the quicker it goes stale. But there are too many variables like, how old was the fuel when you first purchased it, is your talk sealed properly, was the cap opened at any point etc
I'm no expert, just going off what I've read online, and what I've been told. When you're given 40L of free fuel and you hear the story behind it you tent to agree.
Edited by Stagea97
https://www.sau.com.au/forums/topic/439550-stale-fuel/#findComment-7207520
i'm in a similar situation. the current fuel in my V35 350GT has been in there since ~ 19th november last year. at the time i used a octane booster ( not really sure if they actually do anything or are just a waste of money), but i cant tell any knocking or signs that the fuel is too bad to run.
its deffinatly not as fresh as what it used to be tho
https://www.sau.com.au/forums/topic/439550-stale-fuel/#findComment-7207919
6 months is about how long it would go before things start to change. As long as it's in an air tight, stable temp place.
Some premiums get shipped in bulk tankers from O/S. I think if the life span was two weeks, this would be a rather pointless exercise.
Two stroke stuff, I try not to keep the same mix for more than 3 months.
https://www.sau.com.au/forums/topic/439550-stale-fuel/#findComment-7208439
i work a 3 on 1 off roster and find fuel in my daily (cammed ss ute) goes off and runs like shit until i get a fresh batch in, so now i aim to leave as little as possible in the car while i am away and get a fresh tank when i am back for my week.
although the fuel may be several months old by the time it enters our fuel tanks, O&G companies store their fuel specifically to avoid this i.e. most fuel storage has self leveling roofs (dictated by the level of fuel in the storage tank) to minimise the air in the storage. i am no expert but it is my understanding
Edited by janey babey
https://www.sau.com.au/forums/topic/439550-stale-fuel/#findComment-7208494
I guess it depends how anal the owner wants to be and what car the fuel is being run in. Shelf life on normal non ethanol fuel from what research I have done is about 6-12 months without any dramas.
I've used 95-98 octane fuel that has been over 3 years old without any problems in the past. No pinging or power loss and certainly no "BANG". I have a friend that goes overseas and he has a car that sits in a garage that at some point had 5 year old fuel in the tank. He just cranked it and drove.
That said, if you car is tuned to an inch of its life and detonation, I wouldn't want the few to change even a fraction of a %.
Though that 2 week story is a bit absurd IMO especially when you realise the fuel is not made to order for you at the petrol station pump.
https://www.sau.com.au/forums/topic/439550-stale-fuel/#findComment-7210262
This.
6 months is the approx shelf life when stored correctly. That's what Shell have always said. Never been able to find any information from the other companies as easily... So 2 weeks, unlikely.
https://www.sau.com.au/forums/topic/439550-stale-fuel/#findComment-7215660
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
