Std high flow makes 100kws at 3000RPMs and maxing out at 320rwkws on E85. Note this turbo hit 20psi at 3400RPMs, there isn't many turbos out there can do this without chocking the engine tho. Pump 98 fuel usually makes 40kws less. It is cheaper then what cost you to buy a TD06, after testing all this TD06 based turbos, I'm fairly sure it is far more responsive then any thing based in a 10cm turbine and makes more power internally gated.
Added 270214:
labeled dyno reading from 21U high flow internally gated on Stock manifold E85 (take 40kws off for P98 result)
How does the 2IU highflow compare to the atr43ss1PU?
Looks like they both get full boost at 3400, but the ss1pu has 30rwkw more in it? How much physically bigger is the front cover on the ss1pu compared to the highflow?
What's the difference between the two on the street in terms of driveability?
  • Like 1
I think the SS2 or a OP6 high flow will suit your car better.
Reason is I've found out that your car is a AWD GTS4. By experience not only that they are 12% lake in power to the RWD Skylines, they also run the turbine end hotter. The end result will be more successful with a larger rear housing, that makes the engine much happier too.
Other thing need to be understood is turbocharger isn't magic, making 20psi by 3400rpms requires high exhaust gas velocity in low rpms, which does not satisfy the flow requirement in upper rev range or compensate for high boost. There for most 500HP rated turbochargers kicks in 20psi region around 4000RPMs mark using a larger turbine housing.
Solution on the extreme side is high temperature variable turbine geometry system, heat resistant silicon nitrate ball bearing system and high efficiency compressor wheel (ATR43SS-Alpha system). On this setup we can have 20psi by 3500RPMS, make good power while not chocking the engine. Sadly this turbocharger so far can only work on an externally gated system, complicated to build and expansive.
[[/img]
Is the cost of the op6 highflow the same as the cost of the 2IU highflow? I can't seem to find the 'high flows' on your website?
What's the op6 rated too on e85? Do you have an op6 e85 dyno sheet by any chance please?
Cost to high flow is same.
All the results has been indexed on page one of my high flow thread. Along with many other.
21U result is at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__7000
Op6 result is at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-461
Note 4WD systems usually creates a bit more drag, acts very similar to higher dyno ramp. Which usually ends up with better response and less power, probably because the combustion discharging temp is higher under greater load..
  • Like 1
21U result is at:
Op6 result is at:
Have you done much testing with the addition of cams regarding boost response?
Can't wait to have an fresh highflow under the bonnet
The cams I used was 264 dur / 9 Tomei from CJmotor, and only CJmotor has them. That was a waste of time and effort, made 3kws of power differences for 400RPMs of lag. For the HP level expected, standard cams works best.
details are at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-452
details are at:
Jeez.... Glad I spent $700 on tomei 256 poncams.... :/
Unfortunately building turbochargers isn't just about turning lathe, people isn't just buying a turbo, they are buying their desired HP goal. Ensuring the outcome I must not only be an excellent engineer, the engineering must be closely related to the power generating subject which on SAU is a Rb25det motor along with all of its components.
Yes I have a book of dyno sheets contain 1806 pages. that recorded the behavior of a Rb25det in many different aspects, its very useful in directing the shortest path archiving certain performance goals.
I think the issue he was mentioning is with VCT off it fudges the figures a fair bit. You can't say a certain set of cams is no good just because it din't work on your particular setup.
I am of the opinion the stock cams are usually the best option anyway... Upgrading cams is the last thing I would suggest, and only on well sorted high power setups. More important is keeping the gas speeds up.
Yes they will have better low range power because nearly every aftermarket cam shift the powerband slighty up but makes more mid to top power
But with staos car setup it wasn't a fair comparison with stock vs tomei cams as the std had VCt and the tomei didn't
I don't know much about rbs but maybe cause the duration or lift VCt is incompatible but it would be better to compare a smaller aftermarket cam with VCt vs std cam then you can say if it's worth changing cams or not so his test was flawed
  • Like 1
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
