So I'm going to need a security system for my new car. I know next to nothing about them, other than the few things I have read on here.
What alarm systems do you guys have in your Skylines, if any and are there any I should check out/avoid?
Also, I read that recently a bunch of the Melbourne guys paid for Chris Rogers to come down and do some installs for them as well as supply the alarm systems. Is there anyone interested in doing this again? PM me if you are, and I will start a topic in Group Buys and contact Chris and Lifted (the bloke who organised the last lot of installs).
https://www.sau.com.au/forums/topic/439828-i-need-help-with-an-alarm/
This is something nobody should discuss on a public forum. Any decent brand will do.
It's the quality of installation that matters. Hell, a $150 system with a $700 install will stop damn near anyone without access to a flat bed truck.
I believe the man himself will confirm this :yes: (his rates are more reasonable than this of course)
Do you offer cheaper systems Chris? I enquired about the previous round but budget doesn't stretch that far
The extra cost he warrants is definitely worth it imo...wouldn't want him to cheap out on quality just to save a few dollars.
My custom job that finished recently with him (cos them Melbourne boys took priority :down:) cost just north of $1k. Was tempted to go a few hundred more for the 'watertight' treatment but felt it was overkill for a car like mine.
He also gave me some free stuff like a covering of concrete dust so I've now got the matte paint job I've always wanted :blush:
Oops, didn't think about that, lol. I'm guessing I should avoid JB Hi Fi install jobs? Allow me to re-phrase, then. What exactly should I look for in a system? ADR compliance is pretty much required, but are there any other features I should think about?
ADR , tracking option and someone that can install . $5 jb installs are not the go, forget viper products unless thatcham is mentioned.
Correct. Done properly with a decent unit flatbed will be the only way it moves.
Yours wont move in a hurry , we both know why. Countermeasures on countermeasures , the trunk pop went over well too!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
