Hi All,
For sale are a pair of very near new DBA 4000 T3 Slotted Rotors (Rear Only) and brand new RDA pads. I just bought these off a fellow SAU member then realised I had sumitomo rears so couldnt use em.
They've just been machined by racepace so these are good to go. Part number DBA4929S.
Please note these are just the rears and compatible with the rear brakes of the following
Nissan Skyline BNR32 GTR V-Spec (RB26DETT, 02/1993 - 02/1994) (Notes: Brembo Calipers Only)
Nissan Skyline BNR32 GTR V-Spec II (RB26DETT, 02/1994 - 01/1995) (Notes: Brembo Calipers Only)
Nissan Skyline BNR32 GTR V-Spec II N1 (RB26DETT, 02/1994 - 01/1995) (Notes: Brembo Calipers Only)
Nissan Skyline BNR32 GTR V-Spec N1 (RB26DETT, 02/1993 - 02/1994) (Notes: Brembo Calipers Only)
Nissan Skyline BCNR33 GTR (RB26DETT, 01/1995 - 05/1998)
Nissan Skyline BCNR33 GTR V-Spec (RB26DETT, 01/1995 - 05/1998)
Nissan Skyline BCNR33 GTR V-Spec N1 (RB26DETT, 01/1995 - 05/1998)
Nissan Skyline BNR34 GTR (RB26DETT, 01/1999 - 08/2002)
Nissan Skyline BNR34 GTR V-Spec (RB26DETT, 01/1999 - 08/2000)
Nissan Skyline BNR34 GTR V-Spec II (RB26DETT, 08/2000 - 08/2002)
Nissan Skyline BNR34 GTR V-Spec II N1 (RB26DETT, 08/2000 - 08/2002)
Nissan Skyline BNR34 GTR V-Spec N1 (RB26DETT, 01/1999 - 08/2000)
Nissan Stagea WGNC34 260RS, Series 1 (RB26DETT, 11/1997 - 08/19
Looking for $300 or make an offer - happy to post at buyers expense
call or sms 0400 370 477
Located in Mulgrave, Victoria
Cheers
Dennis
  • 1 month later...
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
