Hi. Im modifying my engine atm aiming for 250rwkw. So far I have front mount. 480hp turbo ngk copper .8 gfb 2 ebc. Catch can. High flow cat to custom 3inch back. What injectors will get me to my goal. What fuel pump? Do I need a metal head gasket? What about ffp? Also the biggy the ecu. I do have a tight budget for all this. All help will b appreciated.
Also check out my bake and clutch pedal question need help there also.
https://www.sau.com.au/forums/topic/440316-help-with-r34gtt-mods/
Just realised you are the guy struggling putting a de box into your car.
You will break that box with your car stock.
Why do you want to break it sooner?
Seriously dude, spend the money on a decent box that is not glass so you can enjoy the car.
Anyway here is some advice you must not have heard before
Cheap
Fast
Reliable
You can only pick 2.
^^lol i'm from nz and use ebay haha
if you are in NZ why are you running a CAT? ditch it. you don't need to change head gasket and you do not need a Fuel pressure reg. i'd recommend deutschwerks 320lph pump and there 550cc or larger injectors with a powerfc or link.
Where do you live? If you are in Auckland there is a regular Friday night meet where you can check out what other people have done and get advice and pointed to suppliers etc.
$2500 will only pay for the supply and tuning of a Link. Cheaper is a Nistune chip. Or if you can find Andy (X-Tune) he can tune and custom make a chip for you. He supplied my injectors and can probably also supply a Deatschwerks pump.
Sadly Cats are now mandatory (for about the last year or two).
really? i didn't know that? and my car has been going through warrant testing fine? is it new vehicle compliance or a requirement on all vehicles? i'd be keen to pop along to the friday night meet when i get my P.O.S chinese intercooler sorted.
Thats the impression I was under about the cat to. Qnd yes that is the turbo im using. Im from whangarei mate. Yea link is out of my budget am keen on nistune or the likes but cannot find any1 to install and tune it in auckland.
Tony (SDU president) did a bulk buy on Nistune - don't know if he has any left. Torque Performance can install and tune Nistune possibly Glenn Suckling (Helensville) as well.
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
