Was gonna cruise down kingston se way next week in the rs4s and camp on the beach/sand. I've heard and read on numerous occasions that it's a nice beach to drive on because the sand is good and firm. I'll be honest, I haven't been near here before so I dont really know what to expect.
Has anyone else ever given a bit of awd action of this respect to their stagea? Any tips/advice? How was your experience?
Obviously you wouldn't even try to drive near the water's edge and i'm not about to thrash dunes like I'm a Dakar rally champ.. Just away from the carpark zone enough to be nice and private.
I'm also conscious of the fact that it's rwd bias and not full time awd..
Any thoughts?
https://www.sau.com.au/forums/topic/440498-awd-action/
If you turn the awd lock button on you will get 50/50 front and rear at low speeds but if you don't have huge knobbly tires you will just get 4 wheels spinning! And if it were my car it would soon be sitting on the sills...
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227931
no locked diffs, you will get stuck,
its awd not 4wd,
that being said... camping rocks
actually 99% of 4x4s don't have diff locks. and in general you don't need them for sand driving.
your biggest issue would be lack of clearance and smooth road tyres. if you could keep to the hard packed stuff I can't see it being an issue. Just make sure after you give it a damn good clean to get the salt water off
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227940
Mm.. the no lock diff does have me a bit worried and I am aware of the difference between awd and 4wd. Its at standard height but the tyres are indeed for road use.. but they're brand new.. just didn't want to be out of view of the car in the carpark (although that doesn't matter so much when you're asleep :P).
Also depends on how the conditions are and how I confident I feel at the time
Edited by staglover
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227948
the no diff locks would be the thing to worry about the least. the no low range would be more my worry.
Just make sure you take it easy and limit wheel spin. Keep it to the firm stuff and you will be ok. Its not different to all the subarus you see on the beach.
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227950
what about manuals with the torque split
Are you referring to a manual torque splitter? My stag is a manual, dont have a torque splitter intalled though.
Stags would also be heavier than a scoobie I would suspect..and not fulltime awd like its japanese cousin
Edited by staglover
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227961
RS4S has no lock button Bob.
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227968
thats what i mean. uses the R33 system.
well im interested in hearing how the stag goes on sand, it just reminded me of this thread recently.
http://www.skylinesaustralia.com/forums/topic/439613-stagea-stuck-on-dirt-s2-wgnc34/
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7228170
sorry maby i mean something else, i think it cant lock left to right or something. you can trip them up anywho.
Diff locks are what stops left to right, but as I said 99% of 4x4s don't either. It's only very serious modified trucks that generally have left to right lock.
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7228179
Interesting.. I definitely will post the results if I do end up on the sand. meanwhile, id love to hear more about peoples thoughts on the matter. So far I'm split 50/50 whether or not to do so. Ive also seen people do beach driving in commies/falcons and the like.. even corollas at silver sands.. Edited by staglover
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7228433
Dont see why a stagea wouldnt go very well on firm or even slightly soft sand. As people have said clearance woukd be the issue.. diff locks on sand can help but they can also cause issues. Huge muddies arent needed, the more tread in contact with the sand the better so even dropping the psi like a 4wd'er would help.
Smooth throttle, brake and steering inputs as well as using a bit of momentum if needed and you should do pretty well.
Or create some kind of crazy patrol/stagea hybrid...
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7229574
that sucks man.... lets do an RS4-S beach camping cruze!!!
Im so in right now :D will need at least 3 weeks notice though for work which makes it kinda just 'hope for the best' haha. Not saying we shouldn't though
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7236798
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
