Hey guys new to this so tell me to fxck off and search or what ever but i have done a wee bit.
So, i just shimmed my diff in my r32 as per the diy instructions worked a treat nice and tight, pretty much locked =)
Now i have this weird knocking noise after releasing the clutch into gear and driving slow like something is buggurd in the gearbox.
There is no movement in the diff or shafts and the driveshaft seems good but you can turn it a wee bit and its like the gearbox has a delay to engage, so what in the gearbox would cause this play/knock?
Still drives mint in every gear no noises or crunches
the car was perfect to drive before the tighter diff was in or maybe it wasnt enough to notice it i dont know.
cheers please help =)
https://www.sau.com.au/forums/topic/440501-gearbox-issue-you-might-know/
if there is a clunking noise when you apply or remove power, and you've just shimmed the diff, by far the most likely reason is the backlash is not set properly. Are you confident you followed the right procedure there?
Yeah pretty confident with the car jacked up when you twist the drive shaft back and forth the halve shafts turn with it almost no play there but at the gearbox end you can twist it a bit before you can hear it clunk or engage, is there anything in the gearbox that could cause this keeping in mind that everything else is mint no noises no crunches shifts perfectly etc
Drop the tailshaft and turn the gearbox yoke independently. Then do the same for the diff. Work out where the problem is, because it can be deceiving when it's all hooked up. I'd agree that it sounds like you've got too much backlash in the diff. There's not a whole lot in the gearbox which would cause a delay to take up, unless you're missing teeth or something.
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
