Regretfully selling my 1990 Nissan S13 Silvia as I'm moving overseas. This is the K's model with all optional extras and some light modification. This is a manual CA18DET model with 150,000km on the clock with motor still running strong. Rego until Aug 2014, but selling without RWC (won't be hard, had RWC approved 12 months ago)
Factory features:
ABS, LSD, Sunroof, Leather seats (I have never seen these on another S13 before), Glove compartment cooler box (another rare extra), WORKING airconditioning (omg!!), Remote central locking with alarm.
Mods (off the top of my head):
T28 turbo
Bleed valve
K&N air filter
Front-mount intercooler
Performance coil pack
3 inch catback exhaust
Bosch 040 fuel pump with Z32 fuel filter
Tein Super Street Coilovers front and rear with cambertops
17 inch Advanti Racing wheels (not sure of the specs.. 17x6 maybe?)
SAAS boost and oil pressure guages (not installed)
Also selling with some other bits and pieces including a second boot lid with stock spoiler and 3rd breaklight (to pass RWC)
This isn't the cleanest S13 you'll ever see, but it's a damn good car throughout. It has some great features that are rare, as well as some good, tasteful mods already on to get you started. I had so many plans for this car that I'm unable to follow through with because I'm moving to Japan and unable to keep it sitting around for years. With the right care, this car will without a doubt hold it's value or even increase in value as more S13s are stripped and thrashed into track cars or wrapped around poles.
Asking $6,000 ono. Low-ballers will be ignored. Reasonable offers will be considered.
Located in St Kilda. Come check it out, and no time wasters as this will definitely sell.
Call me or text 0-4-3-0- 0-2-6- 6-0-3
https://www.sau.com.au/forums/topic/440671-vic-1990-nissan-silvia-ks-s13/
  • 1 month later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
