A guy with PT5558 on R34 neo made 372rwkw @26psi, the only difference- he had e85, top mount ex manifold and ffp. Mick O made 335kw on stock manifold btw...
In this case the OP6 high flow made more power on less boobst :P
Like mentioned earlier, higher octane fuel will allow you to run timing that is closer to the optimum degree.
Or you can also enlarge the exhaust side turbine wheel that has similar effect to an larger rear housing. This case a larger housing would be the cheaper way to get more power.
What I was tryin to say is I dont think the turbo is a limitation itself since 372kw and 360kw was made with the same turbo on a neo and an sr (both e85) respectively, as posted by the guy above. And mick O did 335kw on stock mani, so have many others gone over 300 on stock mani. Just my opinion
Well SR20det in .63 is equivalent to an RB on something like a .84. That R34 has much better hot side setup then yours and on E85.
Like mentioned earlier, Tuning P98 with a tinny rear housing will need to have detonation in mind, in which you will have to back off timing from the optimum ignition angle to avoid pinning. You have less of this issue tuning E85 fuel, that allows you to fire spark closer or at the crank angle for optimum engine output.
Or you can just run E85, which should boost up 40KWs in power getting you over the 300rwkws mark on the same boost level.
Edit:
Add in one more piece of information: Garrett GT30's turbine is in 60in / 55ex. The tip height and exducer area determines the total capacity of discharging, so technically this turbine does not have much better capacity to a GT30 turbine.
How much more power do you think a 0.82 housing will give me? 10kw? Not worth the removal/fabrication of gate/ labor again I think.
Yavuz suggested cams and also an ebc to keep boost up. Any guesses as to how much I will gain with an ebc holding boost well. 280rwkw was made on 18psi not 22.
If it was CAS, a tuner like Yavuz or even Mark should have been able to pick it up straight away and inform me? Or tested a different one. Well changing the exhaust definitely did feel a noticeable gain on the road from driving feel (without touch up tune), after the touch up tune it felt a lot lighter and torqueyer down low, so definitely the exhaust had some restriction. One strange thing now 100km/h in 5th is @2600rpms, before exhaust/touch up tune 100km/h was at 3000rpms...
Cams in a rb as tested by Tao only gain very little but shift power band higher
Where as you where making 200kw by 4000rpm it will proberly be 150kw and full boost will be later as well so won't be good for street and be felt at the track only
You should have ran your nistune tuned by Jem with 287kw on Unigroup dyno and seen where it was at to compare but does it feel quicker than before or the same ?
You can't establish anything from that test, as it lost vct. And you are guessing wildly.
There are results of cams picking up power everywhere, for example Matt from Nistune's r34.
It doesn't feel quicker, much less the same, maybe pulls a wee bit harder in 3rd/4th and a lot better under 3000rpms - more light/torquey down low, this is the area that wasn't tuned well with Nistune. Also cold starts and idle is much smoother and like factory now, before was rough and I had to crank twice/push gas pedal to start.
That's a shame that your Nistune wasn't tuned correctly. Don't blame the ecu.
It would have to be the easiest ecu to get cold start and idling nice with.
That makes no sense.
Diff ratio is the same. Revs the same.
More revs needed before for same power/speed looks like it? Remember its a freer exhaust now, so boosts quicker and makes more power at least 400rpms earlier. And more timing been added across the rpm scale. And yeh they didn't tune the Nistune correctly, not even after the second time.
That doesn't make any sense. If you had 1000hp it should still sit on the same rpm at 100km/h.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
