Just got a set of C5C's sent over from Japan, and my old wheel nuts don't appear to be long enough to screw on, as the head of the nut sits inside the hole too far in. Doing a bit of research, I found this pic:
Anyone know what type of wheel nut is being used here? It looks like it is secured from the inside rather than screwed on the outside like normal.
https://www.sau.com.au/forums/topic/440936-wheel-nuts-for-panasport-g7-c5c/
They're just an internal drive wheel nut (aka 'tuner' nuts, or internal drive). Readily available. If you're using extended wheel nuts, just ensure that you bottom out the nut, and not the drive tool against the stud if that makes sense.
Example from google;
http://www.carmodsaustralia.com.au/titan-tuner-wheel-nuts-set-of-20-subaru-titanium-look-cmatunertitanium
Just get longer chrome plated steel nuts. Aluminium wheel nuts are not acceptable here are some steel nuts - you will need to see if they are long enough :
http://www.ebay.com.au/itm/RED-STEEL-TUNER-WHEEL-NUTS-x20-ROTA-M12x1-25mm-/151084524636?pt=AU_Car_Parts_Accessories&hash=item232d56e45c
or
http://www.ebay.com.au/itm/BLACK-STEEL-WHEEL-NUTS-x20-ROTA-M12x1-25mm-/161178369963?pt=AU_Car_Parts_Accessories&hash=item2586fabfab
(don't know why the don't give the length - you will have to ask.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
