Just converted my rb25 s13 to e85. the car feels a lot faster but should it be making full boost sooner???
also puzzled at how boost and power comes on later than the bp98 .....
Has the following mods:
Standard rebuilt rb25
acl bearings
arp bolts throughout
tomei poncams
hks ex cam gear +8 i think
hks gtrs turbo kit on standard manifold,
custom japan made r32 gtr 6 throttle plenum
retains standard side feeds high flowed 740cc
greddy cooler
apexi induction kit and pod
turbosmart plumb back bov
3inch turbo back exhaust 100cell cat straight through to twin cannons
power fc
walbro 460
tomei fpr
koyo rad and greddy oil cooler
blitz spec r boost controll
excedy light flywheel
nismo 2way lsd
etc...etc..
the bottom red line in dyno 1&2 is the bp98 18psi
the middle pink line in dyno 1&2 is E85 on the same boost
the top orange line in dyno 1&2 is E85 20psi and some tweaking
dyno 3 is just differant boost settings after it was tuned obviously....
What do you use the car for? If it's a daily made he backed off the spool time a little bit so you don't end up pointing the wrong way down the street after a round about?
It is still making more power despite less boost (to be expected with the e85). Maybe he was having traction issues, or clutch slip, or something similar. That turbo would come onto boost pretty freaking hard so did the tuner mention anything about that?
"backed off the spool a little bit" couldn't help but laugh a bit sorry mate.
E85 won't make the turbo boost earlier. It makes slightly more power for the same amount of air. Air is what spins the turbo though.
Should be about the same response wise just faster on boost.
edit: It looks slightly laggy for your set up though, I don't know what ramp rate the dyno operator was using. hard to compare that to the street.
You could try preloading the wastegate slightly or increasing the GAIN setting on your eboost controller
Edited by Blackkers
Yeah certainly no mechanic :)
Basically what I mean though, the gain on the boost controller was turned down. I've heard of people with e85 and a gt ss and the word 'undriveable' was thrown around a lot, there was just too much torque and it drove like it was on ice.
Ask tuner why. Then you will know.
I wouldn't be happy with later spooling on e85 tune. Perhaps that's why the afr is not shown on the plot..... cos that's what you should be interested in, boost you can see for yourself on the road. (They don't tune the boost, they tune the afr and timing)
he could turn gain down on the boost controller to make it spooler slower couldn't he?
It's mostly a street car but fully equipped for drift...it's feels noticeably faster actually driving it on the street now (e85) then before on bp98.. I am now having even more trouble getting any good amount of power to the road without wheel spin (rsr semies)
It had year old good tyres on when was on the dyno....one did internally delaminate towards the end tho haha....
400HP and spinning wheels with semi slicks?
Yeah right. What suspension are you running or as said camber?
There is no way you should be losing traction with that power.
My experience with a GTRS on a 25 with E70 was it wanted to boost at 2200 revs and it felt like it couldn't breathe and did the ethanol "wobble" thing . I suspect that until the waste gate cracks open there is more air going in than the turbine housing itself can pass out so you get I suppose a locked up volume situation that the engine can't handle unless you back off or allow the gate to crack open at that point . You can drive a GTS25T up some surprising grades in 5th gear and silly low revs with a GTRS and E70/85 - if you can get the exhaust out through the combined housing and gate . If you go with the stay shut f**k you gate theory I think you'll choke the thing at low revs trying to get boost in when the engine can't really use it . The surge slotted compressor housing gets around compressor surge issues but you really need the gate to crack early and some electronic means of boost control to get adequate exhaust flow out of the engine .
Really people have to think about how much boost you jamb into an engine at low revs and how much it pays off - or doesn't actually . If you had a multi needle gauge showing boost and exhaust manifold pressure you'd be surprised what happens at times .
I never ran my GTRS on straight PULP but I'm sure the ahh hot side restrictions would have shown up as detonation and countering that would stop you forcing them into boost at real low revs . Ethanol is good stuff but I reckon it can resolve detonation issues in a setup that's trying to tell you it has a problem . I'm choking even if I'm not detonating ...
A .
It's a set up drift car it has adjustable and solid everything (bushes/arms) and a fair bit of body bracing/rollcage/heavy as swaybars and yes it runs a fair bit of camber can't remember exactly how much but I run shitty rotas 18x10 and 18x12...... Don't forget it's 400whp rb25 s13 mostly stripped out for weight reduction it had no problems spinning the semis befor e85
Also forgot to mention Matty put a sensor in the o2 plug on the dump and measured 4psi of back pressure at 20psi boost....
I'm installing a flanged allflow non cat and having smoke machine boost leak test done by a friend in the next few weeks and then back to Matty at pits for a re tune and to tune the throttles as well so well see how all that goes lol
Is the bong smoke machine under pressure? If not, don't even bother, just make a bung and cram some air into it. 20psi should do nicely if you can keep it in there.
Yeah man it is under pressure.... a friend at VAGarage has one he uses regularly to test and fix all the Audi/vw turbo cars he works on
lol. VAG. :P
I still don't understand why you would need the smoke, I test intakes all the time and have no issue finding leaks with plain air, I just figured it was a way of charging more for what should take 10 seconds with a compressor. Try 40psi if you want to find them easier. ;)
some water and liquid soap in a spray bottle works mint too. ;)
Yeah tried this it does the job too but when you fit a set of gtr throttles to an rb25 there are a lot o extra vacuum lines under the plenum you can't get to so the smoke test is all round easier (:
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
