Just converted my rb25 s13 to e85. the car feels a lot faster but should it be making full boost sooner???
also puzzled at how boost and power comes on later than the bp98 .....
Has the following mods:
Standard rebuilt rb25
acl bearings
arp bolts throughout
tomei poncams
hks ex cam gear +8 i think
hks gtrs turbo kit on standard manifold,
custom japan made r32 gtr 6 throttle plenum
retains standard side feeds high flowed 740cc
greddy cooler
apexi induction kit and pod
turbosmart plumb back bov
3inch turbo back exhaust 100cell cat straight through to twin cannons
power fc
walbro 460
tomei fpr
koyo rad and greddy oil cooler
blitz spec r boost controll
excedy light flywheel
nismo 2way lsd
etc...etc..
the bottom red line in dyno 1&2 is the bp98 18psi
the middle pink line in dyno 1&2 is E85 on the same boost
the top orange line in dyno 1&2 is E85 20psi and some tweaking
dyno 3 is just differant boost settings after it was tuned obviously....
What do you use the car for? If it's a daily made he backed off the spool time a little bit so you don't end up pointing the wrong way down the street after a round about?
It is still making more power despite less boost (to be expected with the e85). Maybe he was having traction issues, or clutch slip, or something similar. That turbo would come onto boost pretty freaking hard so did the tuner mention anything about that?
"backed off the spool a little bit" couldn't help but laugh a bit sorry mate.
E85 won't make the turbo boost earlier. It makes slightly more power for the same amount of air. Air is what spins the turbo though.
Should be about the same response wise just faster on boost.
edit: It looks slightly laggy for your set up though, I don't know what ramp rate the dyno operator was using. hard to compare that to the street.
You could try preloading the wastegate slightly or increasing the GAIN setting on your eboost controller
Edited by Blackkers
Yeah certainly no mechanic :)
Basically what I mean though, the gain on the boost controller was turned down. I've heard of people with e85 and a gt ss and the word 'undriveable' was thrown around a lot, there was just too much torque and it drove like it was on ice.
Ask tuner why. Then you will know.
I wouldn't be happy with later spooling on e85 tune. Perhaps that's why the afr is not shown on the plot..... cos that's what you should be interested in, boost you can see for yourself on the road. (They don't tune the boost, they tune the afr and timing)
he could turn gain down on the boost controller to make it spooler slower couldn't he?
It's mostly a street car but fully equipped for drift...it's feels noticeably faster actually driving it on the street now (e85) then before on bp98.. I am now having even more trouble getting any good amount of power to the road without wheel spin (rsr semies)
It had year old good tyres on when was on the dyno....one did internally delaminate towards the end tho haha....
400HP and spinning wheels with semi slicks?
Yeah right. What suspension are you running or as said camber?
There is no way you should be losing traction with that power.
My experience with a GTRS on a 25 with E70 was it wanted to boost at 2200 revs and it felt like it couldn't breathe and did the ethanol "wobble" thing . I suspect that until the waste gate cracks open there is more air going in than the turbine housing itself can pass out so you get I suppose a locked up volume situation that the engine can't handle unless you back off or allow the gate to crack open at that point . You can drive a GTS25T up some surprising grades in 5th gear and silly low revs with a GTRS and E70/85 - if you can get the exhaust out through the combined housing and gate . If you go with the stay shut f**k you gate theory I think you'll choke the thing at low revs trying to get boost in when the engine can't really use it . The surge slotted compressor housing gets around compressor surge issues but you really need the gate to crack early and some electronic means of boost control to get adequate exhaust flow out of the engine .
Really people have to think about how much boost you jamb into an engine at low revs and how much it pays off - or doesn't actually . If you had a multi needle gauge showing boost and exhaust manifold pressure you'd be surprised what happens at times .
I never ran my GTRS on straight PULP but I'm sure the ahh hot side restrictions would have shown up as detonation and countering that would stop you forcing them into boost at real low revs . Ethanol is good stuff but I reckon it can resolve detonation issues in a setup that's trying to tell you it has a problem . I'm choking even if I'm not detonating ...
A .
It's a set up drift car it has adjustable and solid everything (bushes/arms) and a fair bit of body bracing/rollcage/heavy as swaybars and yes it runs a fair bit of camber can't remember exactly how much but I run shitty rotas 18x10 and 18x12...... Don't forget it's 400whp rb25 s13 mostly stripped out for weight reduction it had no problems spinning the semis befor e85
Also forgot to mention Matty put a sensor in the o2 plug on the dump and measured 4psi of back pressure at 20psi boost....
I'm installing a flanged allflow non cat and having smoke machine boost leak test done by a friend in the next few weeks and then back to Matty at pits for a re tune and to tune the throttles as well so well see how all that goes lol
Is the bong smoke machine under pressure? If not, don't even bother, just make a bung and cram some air into it. 20psi should do nicely if you can keep it in there.
Yeah man it is under pressure.... a friend at VAGarage has one he uses regularly to test and fix all the Audi/vw turbo cars he works on
lol. VAG. :P
I still don't understand why you would need the smoke, I test intakes all the time and have no issue finding leaks with plain air, I just figured it was a way of charging more for what should take 10 seconds with a compressor. Try 40psi if you want to find them easier. ;)
some water and liquid soap in a spray bottle works mint too. ;)
Yeah tried this it does the job too but when you fit a set of gtr throttles to an rb25 there are a lot o extra vacuum lines under the plenum you can't get to so the smoke test is all round easier (:
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
