All pics are here: http://1drv.ms/1fW8hcO
Can post some items.
R32 coupe door glass LH and RH, $15 each PICKUP only
R32 GTST Standard airbox $20
R32 front guards. All panels straight and rust free. LH (gold-suit repainting) $25 & 2xRH (1xgold-suit repainting) $25, (1xgunmetal grey one large scratch) $45. Pick up only.
R32 GTST rear bar (needs repainting), reo, reverse lights and number plate lights. $60 Pick up only
R32 GTST door cards LH & RH $15 each Pick up only
R32 coupe 2 x driver side window/mirror switch. $20 each
R32 coupe Passenger side window switch $5.
R32 climate control/aircon control box $10
R32 GTST gauge surround with switches shown in pic. $20
R32 assorted switches including clockspring and indicator stalk. $20
for the set shown in pic.
R32 radiator and fan shroud. Not sure if radiator leaks but looks ok. $20 for both. Pickup only.
R32 standard front strut brace $15 Pickup only.
R32 GTST type M side skirts, includes rear quarter skirts. Needs repainting, RH skirt has minor damage but hardly recogniseable when on the car. $40 for the set. Pickup only.
R32/R33 rear hicas lockbar $10.
R32 projector headlights RH and LH, $40 each.
R32 GTST clear aftermarket indicators, one of the tabs is broken but can easily be secured with zip ties. Sell as pair $40
R32 coupe rear taillights (needs repainting) $50 pair.
R32 coupe boot seal in excellent condition $5
R32 manual centre console surround, manual boot needs replacing. $15.
R32 blower motor fan $10
R32 coupe window motor assembly 1x LH & 2xRH. $10 each
R32 handbrake lever. $10.
R33 GTST rear Ohlins shocks and springs. Height adjustable (circlip) and damper adjustable, In good working order, no leaks. $50 set PICK UP ONLY.
R33 RB25DET Series 1 camshafts (set) $30
R33 RB25DET Series 1 factory coils, set of 6. $50
HKS mushroom pod filter suit RB. $15
Turbosmart Vee Port atmo bov. Bolt on for RB20/25 $20
Will consider straight swaps for:
Unmarked top half R33 dash.
Full R33 boot interior.
Edited by Alf
https://www.sau.com.au/forums/topic/441140-qld-various-r32-r33-parts/
Centre console surround, door cards, rear taillights, gauge (cluster) surround, rear Ohlins shocks and front bumper SOLD
Strut brace https://ljb9mg.dm2303.livefilestore.com/y2pbqpJCsEeRnRZatGzSvRWYrDzrMYZFYPAINiJxff9fsgjv6CyE6xxMFLO83jntgHJww91DrmBtU97XHFiqwdAJujbCuO2mv62-hVJ4qLtaXg/100_0056.JPG?psid=1
Can you put up a pic of the air box thanks. Might be interested pending the shape.
(Missing an air box and haven't any clue what they look like stock) sorry for the odd question.
Cheers
http://i1372.photobucket.com/albums/ag338/brian30det/100_0027_zpsf91a8258.jpg
http://i1372.photobucket.com/albums/ag338/brian30det/100_0026_zps9916a590.jpg
Brilliant, I'll take it please. I'll be able to make this work easier then folding up a alloy box I had in mind.
If you PM me your details ill deposit the money.
Regarding freight as I'm in adelaide. I can organise TNT to collect it from you if you could box it up and label it with some shipping details.
Thank you.
Chris,
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
