Pretty much as the title says. It's and auto s1 stagea but still just a 25. All stock except bov have been plumbed up. had this issue before I did that. Read heaps of forums and did most of the things suggested (cleaning aac etc) afm seems fine but hard to call. Any ideas? It's drivable but will stall out when you back off at a slow rolling speed so I pretty much idle through carparks.
have you set your idle correctly? get the car up to temp stop the car...unplug the tps....start the car...turn the idle screw on the aac valve till you have it idling at 750. turn car off...plug the tps back in.....if it still runs like shit after that it could be your tps.
Cheers badgaz will do that in the morn. Bov has been deleted completely and made a new intake pipe
Why?
Put recirc bov back on.
The reverb screws around with the airflow meter reading leading to the issue you have described.
Well, your initial post isn't particularly clear. I suppose you are in a rush for people to help fix your problem.
Somehow bov plumbed up equals blocked off?
Was it previously the stock bov recirculating as per stock?
I usually pretty much idle through car parks also, lots safer than boosting through them.
Superben. Firstly thanks for a mature comment. the engine was completely stock in every way and had the ssame issue. As for the bov, New intake pipe deleted that line, blocked other lines and put a plate over the bov where it goes into the manifold.
It's not the issue.
As for idling through Carparks I have no issue with that. It's a daily running stock boost. It IS drivable. just any speed below around 50km if you completely release the throttle it will die the revs down to almost a stall.
Productive comments are appreciated. if not fk off to boostcruising. Cheers
Typical as the new guy to a forum you would ease into things before potentially offending knowledgeable people who were willing to take their time to help you.
It's pretty hard to judge someone's true character based on a few (or even alot) of posts.
Not sure if your trying to have a dig or not. Signed up and posted in hope of getting some useful feedback from other owners, which in fact I got. The other comments are useless and there's no need for them. I referred to boostcruising for obvious reasons. I thought maybe a website dedicated to specific cars might have been a little different. Maybe your all having a lend and think it's funny? Sorry can't tell, this is text after all. I have stated that positive feedback is appreciated and will continue to thank those who are actually knowledgeable and offering their help.
+1 for BOV not helping the situation.
I have an auto R33 atm and since putting a Blitz atmo on back off it almost stalls. But I live with it for the hektik doses it does :yucky: ..
I'd be pressure testing the system for leaks as they will also create stall issues along with the bov set-up..
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
