If your idle is 1000 rpm with the tps disconnected then you need to adjust the idle down to 750 before checking the timing again as it may be slightly different.
As for sounding like a wrx, generally if it sounds like that then a cylinder isn't firing, from either lack of fuel or spark. Did you disconnect anything to do with fuel or ignition when you did the timing belt?
I checked it with a timing light the usual way man
I just forgot to buy a spark plug lead when I was at sprints buying the new plugs
And yeah mad082 your right, ill have to check the fsm to find out exactly the rpm I need
Misfire ended up being coilpack wiring so it idles so nicely now
yeah just checked the fsm it says 650
but your right thats very low
so it says 650 and 15 degrees +/- 2
so ill aim for 750 and 15 ish
if i get that right does that mean its set up properly now and should be fine to drive?
thanks for your help guys especially cal, helped with heaps lately
car might make matsuri now haha
What do u mean , you just said 650 ?
Ive set it at about 750- 800 now, idle is about 18 ish degrees advanced
Ecu is still pulling the timing back when it's under load
Going to check for codes tomorrow, won't be surprised if I see knock sensor code
What do you mean "under load"? The engine isn't really "under load" at idle.
You don't get a "knock" code if you have knock, you get a "knock" code if there is a problem with the knock sensors or circuitry.
  • Like 1
so i think being an old 89 gtst my ecu only has one diagnostic mode
self diagnostics? or real time...
which is giving me the all clear, code 55,
but going up the road, its still running majorly retarded and the exhaust temp light is flashing and so is the ecu light
its just flashing randomly, not any particular code or number or sequence..
does this mean the old ecus are real time or self diagnostic?
like, do i have to drive it to pick up ecu fault codes, or does it log the last 50 starts or whatever it is and remembers if it picked up a code or not
because its giving me no codes,... but still running with no power
cant find much info on it, there is only info on how to use the diagnostics, not whether its real time or self.
or whether there is different modes or not
just read this like straight after
http://performanceforums.com/forums/archive/index.php/t-67188185.html
single led ecus record last 50 starts and will flash error codes from the last 50 starts
so ive got no ecu codes
yet my ecu is still retarding the timing,
also i forgot to mention, i relocated the fuse box and moved the battery to the boot at the same time as this work. probably important, but nothing on the fuse box was cut
i might try resetting the ecu and see what that does because the leds shouldnt be flashing as im driving.
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
