  • Replies 42
ill take the bonnet for 600 in 2 weeks if still there for sure
just need to save a lil more
Edited by gttiwanna
Hinges and the bonnet latch mount are available from Nissan and aren't all that expensive.
Wouldn't say they were cheap either. $255 for a set of bonnet hinges.
Edited by Nooba
Thanks for that, as stated I can also supply hinges free of charge. They appear to modified gtt hinges that were used on a r324. Would probably fit a r34 also.
I do have a spare but it's not included in the price of the plenum. It has the water temp sensors and crank case vent valve? but not the cast piece that fits to the radiator hose.
Of course just let me dig it out and I'll let you know a price. Just to let you know I did have someone interested in it last week but I haven't herd back from them.
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
