Hi guys,
I just finished my first real alloy fabrication project.
I bought a TIG about 2 months ago for some weekend fun :)
Decided to make a catch can/washer bottle for my R33 out of 2mm alloy sheet.
I'm still trying to get the hand and feed speed right, but hopefully more seat time will help!
Any tips or criticism would be greatly appreciated!
Chris :)
post-55684-13964117687792_thumb.jpgpost-55684-13964117897538_thumb.jpgpost-55684-13964118094256_thumb.jpg
https://www.sau.com.au/forums/topic/441396-first-attempt-at-alloy-fabrication/
Looks pretty good to me. Better than some workshops. :)
Practice is the only way to get better. Were you using a foot pedal? I gotta get me one, stopping to turn the dial down as the work heats up is a pita.
The cap was an eBay job- cost $28 including postage which i thought was reasonable.
I am just using the T2 control on the torch at the moment but would like to get a pedal in the future.
My biggest challenge is training my left-hand to feed properly!
Looks good, try stepping up to 3mm for items like these, makes life a hell of alot easier and you dont need to worry about a foot pedal for the tig, I'm a boily by trade who does way to much tig and i f**king hate foot pedals. If you're having lots of problems with heat soaking the material my advice is to Tack it how you want, than put a solid tack on each outside corner were the 3 pieces of material come together than its simple a case of welding from one tack to the other and blowing the material offf with an air gun inbetween runs aswell as dropping the amperage a a touch after the first few. If you feel its getting to hot Let it sit there for 10-15 minutes inbetween runs.. Take your time and be patient.
  • Like 1
Getting there bud, tonal it easier to get even ripples, get the use the move, stop, add technique makes it a lot easier to get the " stack of dimes" beads as both hands don't have to work at the same time with bigger runs I make tacks in the corners then 4 inches apart with no filler so it doesn't ruin the run you are about to do and clean surfaces and good fit is key, have fun mate
  • 3 weeks later...
Nah wasn't me it was probably a bloke called David lol.
My car is off the road at the moment getting a new turbo upgrade so hopefully will be out and about again soon. One of your catch cans would finish it off nicely I reckon ;)
If you're serious about a catch can PM me, I've just moved up to darwin and have a little bit of time to do small fab jobs. Also check my thread in the fabrication section if you want to see previous work i've done.
For anyone who is interested I have another one which is almost finished.
Don't have any idea what they are worth to sell but Ill post a picture of the finished item and if someone wants to make an offer on it, go for it!
Cheers
Chris
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
