I don't think its fair to talk about twin scroll in light of gains over open, not at all. I believe it is more so a different result than it is an improvement as such.
The twin scroll will definitely bring boost on earlier but will also roll on/off smoother and give an overall more linear feel. Not everyone is into that, Owen's GTX is a good example. He and I had many a PM about that and it was honestly determined that he just wasn't happy with the twin scroll efforts. He much preferred the brute delivery of the open .82
In my own experience I am much the same. Not worried about smooth roll ons and how early it starts to make 'some' power. I am more concerned about how easily accessible power is and how hard it will pull at that point. For that I would say a good open housing will definitely deliver.
  • Like 1
Artz
PM me your address, I'll send you my broken CT12a's after I rip them off the Snoarer, long as you're happy to pay the post
yeah that would be sweet....you broke them? just blown turbines I assume...
have you fixed your boost creep issue with the internal wastegate ?
Never really had boost creep problems, it's a back pressure issue. The exhaust housing I have is a little small for my RB30 with it's ported head, but I'm completely happy with the result I've got.......it's got easily enough HP for a road car (630 4whp) and the response is awesome. I could get more out of it if I changed to the larger housing, but I'm not going to bother.
  • Like 1
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
