Hey guys,
Have a complete wreck for sale, shell is damaged beyond repair (side impact)
Parts will be available around 23/4/2014 as im off overseas for a bit
I will take deposits to hold onto parts though
Prices are nego.. no low balling!
Car:
BNR32 GTR, Silver (side impact damage)
BBS wheels, more info TBC - $ TBC
Body:
Front bumper with lip, average condition, lip has crack but will be repaired - $450
Headlights (pair) with indicators, great condition - $250
Bonnet, good condition - $450
Rear bumper, good condition - $200
Boot lid, good condition - $200
Rear wing, missing some paint - $180
Drivers side door, good condition - $100
Rear drivers quarter panel, good condition - $100
Drivers side quarter panel, good condition - $100
Drivers side skirt, good condition - $80
Tail lights, great condition - $250
Interior:
Door trims (ea) - $100
Rear trims (ea) - $50
Velo seat, good condition, one tear upper right shoulder - $550
Passenger GTR seat, good condition - $250
Rear seats, average condition - $200
Carpet, good condition, wear on drivers side - $100
Centre Console with trim around centre fascia, good condition - $50
Dash with glove box, good condition - $150
Tomei 310kph cluster, great condition - $550
3 gauge cluster, volt, oil, boost, good condition - $150
GTR steering wheel, average condition - $70
GTR gearknob, average condition - $30
Boot surround, average condition - $50
Passenger power window switch, good condition - $70
Drivers power window switch, good condition - $100
Engine:
R34 GTR Vspec II, RB26DETT
- ~90,000km genuine
- taken out of a R34 GTR to make way for N1 motor
- never been opened, stock manifolds and turbo
- custom 9L sump setup
- apparently running around 380hp on the Nistune
- will come with all manifolds, injectors, etc. drop in running motor with turbos
$7,500
ECU
R32 computer with Nistune piggyback - $600
Intake:
Large FMIC, with stock piping and greddy elbow, good condition, brand TBC - $TBC
ARC twin super induction box, average condition - $700
2x genuine Nissan GTR AFM, good condition, could be NISMO - $220ea
Exhaust:
Twin dump pipes, brand TBC, good condition - $TBC
Apexi N1, good condition - $550
Drivetrain:
ORC 559 twin plate clutch and flywheel, great condition, ~10,000km - $1,500
R32 Gearbox, good condition, $1,000
Suspension/bracing:
Bilstein damper and springs, lowered, good condition - $800
OEM strut brace, good condition - $150
Adjustable rear camber arms, brand TBC - $TBC
Other suspension TBC
Braking:
OEM GTR front calipers and discs, with lines, good condition - $550
OEM GTR rear calipers and discs, with lines, good condition - $450
Brake booster and reservior, good condition - $120
Cooling:
OEM radiator, fan, shroud and cap - $150
Silicone hoses - $30
Other:
Catch can set up, good condition - $100
Battery, good condition - $70
Edited by Jezzza
Cant seem to edit my first post :(
Also have all drivetrain
Front diff, good condition - $500
Rear diff, good condition - $500
Front tailshaft, from gearbox - $150
Rear tailshaft - $250
OEM swaybars - $100 ea
Edited by Jezzza
Interested in the exhaust setup (dumps, front pipes and cat back) depending on size. Don't suppose you can get any internal diameter measurements?
Otherwise I'll wait til you get back.
Hello,
interested in rear interior trim (passenger side) - particularly the vinyl covered part for the lower part of the b-pillar and then extending back.
Also dash if no bubble in usual spot.....
Please pm pictures :-)
Cheers
Andreas
rear interior trims on hold..
b-pillar trim I have
Cant see bubles in dash, but a small tear/rip? Will get pics
Cheers
The Baron
Really?
You end your messages by typing in a signature each time?
The Baron?
Yes - yes I do...
sometimes I personalise the message for example:
Cheers
The personal Baron
Cheers
The not sure why I do this - but it amuses me Baron ;-)
Anyone wanting pictures, please send me a text
0424 193 992
Sorry I cant seem to edit posts at the moment, so cant add pictures to top thread starter
  • 8 months later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
